1999 E430 AC Blows cold, but only on high speed
Old Apr 24, 2014 | 12:20 PM
rgottschalklaw's Avatar
05ML500, 05CLK320, 98E430, 03C240Wagon, 98C43AMG, 86Porsche911, 00Ferrari456M, 87RenaultGTA
I recently purchased a 1998 E430 and although the AC blows cold, it only blows on the max speed. If I push the (-) button and drop the speed one notch down from max the blower turns off. I read the threads on this common issue, and pulled the blower/regulator. I noticed that the car has the modern blower and regulator set-up, so it must have been converted in its lifetime. I installed a new (modern) regulator (bought from e-bay) and the problem persists. Note that if I unplug the regulator the fan simply does not blow at all. Any experience with this issue? Do I have a bad (new) regulator, or is it something else. Thanks!
Old Apr 25, 2014 | 04:30 PM
matt72's Avatar
c124 124.051
are your cabin filters clean?
Old Apr 25, 2014 | 06:18 PM
Cabin filters are clean. I pulled an OEM unit (blower and regulator) from a donor at a salvage yard. Works 100% now. Also pulled an electric motor for the driver seat headrest, since mine was not working. Again 100% repaired. All for less than $40. Now I have to tackle replacing a rear door power door lock actuator.
