Where's the leak?
Hello. Own a '99 E320 4Matic. Have noticed what appears to be an oil(?) spot located under passenger-side rear tire area. Oil level is fine-any idea what this may be?
Thank you. |
I Put a pan under the vehicle-seems to be a amber-colored fluid leaking from between the two rear wheels-please advise as I don't know much about this stuff...
Thank you. |
Not good with colors-looks like olive oil - not amber.
Just an update: Brought it to a mechanic-rear differential is leaking, seals need to be replaced; also appears front has starting leaking, too. Awaiting estimate for both to be repaired. Anyone have an idea of this cost?
Thank you all for your help... |
I'd be a little curious about that diagnosis. Gear oil is thick, typically gets dark very quickly, and has a pretty awful odor to it.
If the leak is a light colored fluid, I'd be more inclined to believe its brake fluid. |
$1746.00 - you're over...
Originally Posted by Plutoe
(Post 6184323)
Regardless of one or all differential seal replacement---the differential must be removed---my guess is $1746.68 PS: If some SA says this is an easy DIY---run!!
New diff, new brake lines, vacuum lines, etc! Just kidding. Diff shouldn't be horrible if you have the right knowledge and are handy with cars. If not....yea. |
| All times are GMT -4. The time now is 07:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
