New ball joint not the same as old ball joint?
Old Nov 8, 2014 | 10:59 PM
jrnelson's Avatar
1999 E320
Hello all,
I'm having an issue replacing the lower ball joint on the drivers side of my '99 e320.
Where there is a pin on the new ball joint, there is a hole on the old one. The pin is located on the vehicle instead. See pictures below. The pictures don't show it but there is a clear hole instead of the pin.
Either the replacement part is not the same as the old part (searched the web like crazy and cannot find one like the old one) or the pin on the ball joint has seized up to the attachment point and has broken off. However, it really doesn't look like it was broken from the old ball joint.
Any advice would help.
Thanks,
Jordan
Attached Thumbnails New ball joint not the same as old ball joint?-ball-joint-2.jpg   New ball joint not the same as old ball joint?-ball-joint-1.jpg
Old Nov 8, 2014 | 11:37 PM
Fabio D's Avatar
210 55
Remover the old pin from the car/axle and install the new ball joint with the new pin its easy.
Just the old ball joint missing the pin cause they got glued to the cars part, but you can remover it and install the new ball joint complete with the new pin
Other words: remover the old pin from the car and voila
Fabio Daniel
Old Nov 8, 2014 | 11:46 PM
jrnelson's Avatar
1999 E320
Fabio Daniel
That's what I have been trying to do. I covered the old pin in WD40 many times and have tried hammering it out and using lock pliers. It just seems to bend slightly. I'm still not 100% convinced its not actually attached the the car, rather than just seized there.
Here's more pictures I took.
Attached Thumbnails New ball joint not the same as old ball joint?-ball-joint-3.jpg   New ball joint not the same as old ball joint?-ball-joint-4.jpg   New ball joint not the same as old ball joint?-ball-joint-5.jpg   New ball joint not the same as old ball joint?-ball-joint-6.jpg   New ball joint not the same as old ball joint?-ball-joint-7.jpg
Old Nov 8, 2014 | 11:54 PM
jrnelson's Avatar
1999 E320
I'm going just keep spraying WD40 on it for a while and see it that does the trick to get it loose. Other than that and hitting it with a hammer, pulling it out with lock pliers let me know if you have any advice.
My next step would be a blow torch if I had one with me. Unfortunately I do not.
Old Nov 9, 2014 | 10:21 AM
003stars's Avatar
E320
How about this, I will remove the pin on new parts(if you could removed this pin) and put back on to old pin( if old pin is good condition). or last way is you have to fight to remove the old pin on arm without heat. Good luck. 003stars
Old Nov 9, 2014 | 05:05 PM
jrnelson's Avatar
1999 E320
I considered this, but i didn't feel right about leaving the old one in even though it was clearly solid.
I ended up getting a propane torch. 60 seconds on, 5 minutes off, 60 seconds on, 5 minutes off, and then tons of WD40 and it came out.
Old Nov 9, 2014 | 09:10 PM
Fabio D's Avatar
210 55
Hahahahahahah F...ing pin good job man!
Fabio Daniel
