Intermittent Stall When Coming To Stop
Old Jan 16, 2015 | 08:53 PM
cortschrothNJ's Avatar
1999 E320 4Matic Sedan
I have a 99 e320 4matic w/ the m112 and a 722.6, every once in a while ill pull up to a stop and the car will just stall out, it doesn't necessarily happen under any particular conditions, its done it hot/cold/full/empty/coming from high speed/coming from low speed/ect. basically Ive been trying to narrow down specific conditions that it happens but haven't been able to, no check engine light so i don't really think its a tcc solenoid or anything. Ill figure it out eventually but I was wondering if anyone's had a similar issue or if theres a usual cause for this. I have 123k on it and every things maintained, theres a small coolant leak from the pump, the ps lines leak a lil but otherwise every things primo.
Old Jan 20, 2015 | 12:25 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
When I had a faulty MAF sensor my car would do this. Didn't throw a code either...which was strange.
Old Jan 22, 2015 | 07:09 PM
word up and good looks, i need to get my hands on a star scan tool or maybe just a good snap on n check it out cause both those sound plausible.
Old Jan 23, 2015 | 03:52 AM
marc lenssen's Avatar
Maf can be checked by unplugging it. Engine will run on standard mapping. If she then does not stall then you have found the culprit.
But a fresh fuel filter would not harm, cheap and easy trial.
And check the colour and state of the spark plugs, if any have a different colour from the erst you might just have a bad coil or some old or loose ignition leads.
