Help..
Old Feb 11, 2004 | 08:51 PM
lile04's Avatar
drive a 2000 E320 (don't own)
Help..
I have 2000 E320
ok, so here is my problem. I don't know when, where, how but some how there is water mixed with the engine oil.. is this going to harm the engine? if so what can I do to fix this? this car has only 51,xxx original miles.. is it dead??
Old Feb 11, 2004 | 08:56 PM
E55AMG99's Avatar
1951 Caterpiller D6
Re: Help..
Originally posted by lile04
I have 2000 E320
Not dead but dying quickly. Are yo usure there is water in the oil? Is is milky and cloudy? Are you losing coolant? If yes to either, get it diagnosed and repaired ASAP. Usually, water in the oil means bad head gaskets or other uper engine trouble. If you do not act NOW, the Anti-Freeze will destroy the bearings and require you to go through the entire motor.
Old Feb 11, 2004 | 08:59 PM
James F. Cannon's Avatar
2002 E55K RENNtech HP
Exclamation
DO NOT DRIVE IT!!! Call a tow truck to take it to your dealer for diagnosis.
Old Feb 11, 2004 | 09:10 PM
lile04's Avatar
Re: Re: Help..
it is actually a milky brownish color under oil cap
Old Feb 11, 2004 | 09:17 PM
E55AMG99's Avatar
1951 Caterpiller D6
Re: Re: Re: Help..
Well, that is a little different. Get a Topsider oil extraction pump and suck out some oil from the crankcase. Milky oil on the cap can be from condensation that does not get burned off. Do you drive a lot of very short trips? Is it very cold where you are?
Most likely this is the case and nothing to worry about but verify it by checking the crankcase oil.
Old Feb 11, 2004 | 10:06 PM
lile04's Avatar
Re: Re: Re: Re: Help..
yes oh so very cold.. drive less than 5k a year (second owner), there is no white smoke coming from the exhaust which would sigify a blown head gasket. I just don't know?
Old Feb 11, 2004 | 10:12 PM
E55AMG99's Avatar
1951 Caterpiller D6
Re: Re: Re: Re: Re: Help..
Get a sample of the crankcase oil to be sure.
