2001 E320 automatic door locks, interior lights, truck release not working
e320 and e420
Hi everyone,
My automatic doors locks, truck release,and interior lights stop working all of a sudden. I have been using the small silver key to open the driver doors and the trunk. My alarm still works if I open the door with small key before pressing the alarm on my remote. My interior lights won't come on when the door opens unless I manually turn them on. I was told that it could possibly be the PSE pump. Any thoughts/suggestions? Thanks!
Before you jump to that bit of misinformation---when you open the an unlocked door---the door contact switch tells everyone I am opened--then the overhead\rear and dash etc turn on--are you saying that does not happen??
And are you saying that with good key fob batteries that you can't open or lock the doors bla bla??
First I would check all the fuses. There are multiple fuses that feed various components of the PSE. Some are under the back seat in the fuse block next to the PSE and some are under the hood. Also check that the foamy material that the PSE is wrapped in isn't wet. If liquid spilled on the passenger side of the back seat and soaked at material, it could have damaged the pump. That has happened to some members. Mine fried from getting wet during hurricane Sandy. I replaced my PSE with a used pump from eBay.
After pse pump you replace then.. ?
When your pse air vacuum pump quit working and you got a used one via eBay. Did you get the same exact version pump like did all your number match + did you have to do anything after the install. I took mine out. Then my alarm quit working after unplugging the pse pump unit, it was already broken/not engaging the PSE motor ( just click once ). maybe it let out whatever air was still in some of the air lines or back up reservoir. ? Hope I dont need to pay to get it flashed to cars CPU. since its used ebay item I wont know if it works until I get it to work or it fails.
My failure was caused by water penetration from hurricane Sandy. Afterwards I had intermittent locking problems and inability to open my trunk without disconnecting the power from the PSE to reset the pump. After reset, I would be able to open trunk for a day or two, then it would fail. I lived with these conditions until my daughter got a flat on the NJ turnpike and the AAA tech couldn't open the trunk to get the tire out. Embarrassing. After that I went on a mission to find the part on eBay. Found it, sliced in all the wires and installed it, connected the battery, closed my eyes and hit the trunk button on the remote and Click! I was dancing
