Spring tower
Old Aug 20, 2016 | 12:09 AM
Law Lew's Avatar
97 320e mercades
Spring tower
Does anyone know a shop near Plainfield that can repair my spring tower it's not broken but bent
This is the driver side
This is the passenger side
Old Aug 20, 2016 | 12:17 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W210 forum...
Old Aug 20, 2016 | 12:19 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Where da heck is Planfield?
If it is in USA, you can still ask MB USA for good will participation.
Call you friendly SA to start.
Old Aug 20, 2016 | 12:21 AM
Law Lew's Avatar
97 320e mercades
What's that I'm a first time mob owner got the car used don't know much about cars someone told me about this site that they have have some answers if not all
Old Aug 20, 2016 | 12:37 AM
ItalianJoe1's Avatar
2003 CL 600
Body shop. Hard to see from the pic but it looks like the metal is torn. What did you hit?
They will have to remove everything, strip down to bare metal (there's lots of rust on your car), replace any torn or bent pieces with new or good used ones welded back on like factory, then re-seal and insulate all bare metal as factory. Probably $4-5k in repairs done properly.
Buy another car.
Old Aug 20, 2016 | 01:34 AM
kajtek1's Avatar
Still you chose not to disclosure your location, what makes answering you harder.
Those cars had spring perch recall in USA. The time is probably over, but doesn't cost much call Service Adviser at local dealership and ask.
What is really amazing on your perch is that with no sign of rust around, the spot weld corroded.
I zoomed on the picture and did not see to many welds to start with, what makes situation better for you by indicating inferior craftsmanship.
Shops usually charge in the range of $300 for RIVETING new perch. But again, that in USA
Old Aug 20, 2016 | 02:10 AM
Law Lew's Avatar
97 320e mercades
What does that mean?
Old Aug 20, 2016 | 02:59 AM
kajtek1's Avatar
riveting
Old Aug 20, 2016 | 08:57 AM
Law Lew's Avatar
97 320e mercades
riveting
Where can I find that
Old Aug 20, 2016 | 11:02 AM
kajtek1's Avatar
The bridge? Try Brooklyn
The new perches sold by MB USA are rivet-mounted only.
Old Aug 20, 2016 | 01:06 PM
Law Lew's Avatar
97 320e mercades
I found a part through pelican
Was told this is what I need
Old Aug 20, 2016 | 01:15 PM
kajtek1's Avatar
Here you go.
It looks different than MB perches I have seen, but pelican is reputable supplier.
So did you talk to your friendly MB dealer about it?
Old Aug 20, 2016 | 02:00 PM
Law Lew's Avatar
97 320e mercades
Here you go.
Was told they would get back to me😡
