Battery change with under hood battery connections in place
Old Nov 1, 2016 | 11:53 PM
gary87xj6's Avatar
2001 E320; 2006 Mini Cooper S; 2004 V8 4Runner
If I attach a battery via jumper cables to the under hood battery connections (used to jump start vehicle) while I swap out the battery in the back seat will I maintain all of the electrical settings for sunroof, windows, radio, etc.?
This is on my 2001 E320.
Old Nov 2, 2016 | 12:48 AM
fabbrisd1's Avatar
A gaggle of MB's
Frankly - use the opportunity to RESET the settings AND...
1) reset steering angle sensor
2) radio code
3) reset each window and sunroof
the AND... do a forum search and do a ECU/tranny reset after reconnecting the the new battery..
Old Nov 2, 2016 | 01:19 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Having 2 cars in the garage side by side and HD jump cable this is how I did it couple of times.
Not that resetting windows and steering is a big deal, but I had radio code in my home office written on pink slip, so it would take longer to get it.
Just make sure key out of ignition, very good clamping on jump cable and don't touch ground with positive battery cable.
Old Nov 5, 2016 | 08:19 PM
brooktre's Avatar
W220, R170, XU70
I've used a 9 volt battery connected under the hood to keep the settings.
Old Nov 12, 2016 | 12:17 AM
gary87xj6's Avatar
thanks brooktre, that sounds much safer. when I spoke with my mechanic he cautioned me about the approach I planned to take as the battery cables would be 'hot' and any contact could be harmful to the electronics.
Old Nov 16, 2016 | 04:56 PM
01BlackE320's Avatar
01 E320
I connected my battery charger in 2 amp mode when I changed my battery And didn't lose the settings. Yes it's true that the battery cables are hot but just be careful not to let them touch anything. It was easy.
Alternatively its it's not a big deal if it resets
