Question about brake pads
Old 12-10-2016, 07:43 AM
autopressagency's Avatar
W210 E430 Avantgarde
Hello
Going to change my brake pads. So i bought new set of ATE brake pads for my front brakes which are from CLK550 (W209).
So i noticed that the main brake pad has strange metal layer which can be removed. See the images:
So wanna know what does this layer do? I must remove it before install the pads, or it must be mounted on the pads and installed with them?
Tanks
Old 12-11-2016, 12:52 AM
raymond g-'s Avatar
99 E320
google 'ate anti squeal shim' and see what you think. seems that is a
variation on a theme for anti squeal devices
autopressagency (12-11-2016)
Old 12-04-2023, 01:11 PM
ImpliedConsent's Avatar
2018 GLC63S Coupe'
At 38k, I replaced my disc pads with ceramic. We'll see. Can't stand the dust.
Old 12-04-2023, 05:11 PM
ilove190evo's Avatar
2000 E320
Is it made by Galfer? Galfer is well known brand in motorcycle scene. If so, I may go with the same brand brake pad. I'm pretty sure mine needs both the pad and disks.
As for the metal piece, it does look like anti-rattle shim that most brake pads comes with. They have different shapes and colors. You can choose to leave them out. I usually install them with the pad. they are design to be use with it, so why not.
Quick Reply: Question about brake pads
