Help with the name or part number
Old Feb 23, 2018 | 11:51 AM
Prolez's Avatar
W210
Hello, i own a W210 E220 1999 Avantgarde and one of the covers underneath the car broke off. It is the cover thats underneath the engine . Im pretty sure it is the cover you need to remove to change the oil filter but i am having problems figuring out the name or part number for this part and would very much appreciate some help on this! im not sure if this is a 2 part cover or just one, if someone could shed a light on this for me aswell that would be awesome!
Old Feb 23, 2018 | 01:05 PM
Prolez's Avatar
W210
The VIN is WDB2100061A846193
Old Feb 23, 2018 | 01:36 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
http://mb-teilekatalog.info/index.ph...arkt=AG&mmod=E
refer here to your specific model and then go thru perhaps the chassis sheet metal page
Old Feb 23, 2018 | 02:19 PM
Prolez's Avatar
W210
I'll take a look, thank you for the reply!
Old Feb 23, 2018 | 02:25 PM
Prolez's Avatar
W210
i think its #11 on this : http://mb-teilekatalog.info/view_Sub...=52&subgrp=045
Thanks alot for the help!
Old Feb 24, 2018 | 10:32 PM
khomer2's Avatar
Originally Posted by Plutoe
On 611's they are called antinoise capsules---the front is 210 520 19 23; the central 210 520 14 23; the transmission 210 520 20 23
They are called the same thing on the W163s. Not a common item here in NA but are readily installed on the UK and European W163 versions for some reason. Very $$$ from MB.
The baffle sound absorbing on the underside of these antinoise capsules eventually disintegrate over time with the wear and tear of the heat, oil, weathering, etc that it's exposed to. Used versions for sale in UK and Europe show how this "noise absorbing" surface are reduced to nothing. The capsule shells seem to hold up well, however the antinoise surface are pretty much gone after 10+ years of exposure.
Old Feb 25, 2018 | 12:01 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Beware of scammers that will ask for your VIN when no VIN is needed.
The "belly pan" goes via several names as you can already see, but they are not mandatory.
Considering high price for older cars - lot of members drive without it.
Check local junk yard if you can get one for 10 bucks.
