Hydraulic Fluid for Wagon- When to Change the Filter and When to Check It
I had a couple of questions about the hydraulic fluid for the suspension on the wagon.
What temperature should the dipstick be checked for the hydraulic fluid reservoir? Is it a cold or hot dipstick?
Should the filter on the pump be changed and if so at what interval?
Pelican Parts is recommending that I use the Mercedes convertible hydraulic fluid, is this the right one?
Thanks!
With MB fluids - don't listen to the birds and go to dealer to buy the correct stuff. Even at local dealer it is not going to be more than 20 bucks and when you have time, you can order it from internet dealer for less.
