02 E320 losing power, dying
Old Apr 7, 2018 | 07:13 PM
corsair944's Avatar
2015 C63 Coupe
Hi everyone,
Trying to chase down the issue. Intermittently ( favorite issue, I know) car is losing power momentarily while driving, cruise will kick off and many of the lights in the dash come on for a few seconds (5-10) untill normal power is resumed. No CEL at any time. Sometimes the car even dies when sitting at stop light. It has been going on for a few months.
Replaced:
1. CPS (BOSCH)
2. Fuel Filter (MANN)
3. Spark Plugs (BOSCH)
and no improvement.
Car just passed 200K miles.
Anyone had a similar issue? Read many posts on here and cant find anything new I haven't already tried.
Thanks for any input.
Cheers..
Old Apr 8, 2018 | 11:00 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
No check engine light but you should have plenty of stored codes if the dash is lighting up like a Xmas tree. Plutoe's post refers to tire diameters or wheel rotational velocity being out of range and triggering the ESP. Be advised you will need to use STAR and the 38-pin connector under the hood to access all modules; on an '02 the OBD2 port will only touch the motor electronics.
After codes pulled and any issues addressed, then it is time to start chasing gremlins.
Old Apr 8, 2018 | 11:07 AM
corsair944's Avatar
2015 C63 Coupe
All 4 tires are new (3 months) Continentals and pressure is spot on.
we're taking it to my Indy garage tomorrow, Just hoping to get it cured this weekend.
it's my daughters everyday driver so tough to take it for a day.
thanks guys 🍻
Old Sep 19, 2018 | 09:55 AM
corsair944's Avatar
2015 C63 Coupe
UPDATE:
Took car to Indy shop and plugged up to STAR a month or so ago and no codes pertinent to this issue. Of course cant fix a intermittent problem..
Also switched out the clock spring and no change.
Today daughter says car is making a grinding noise when in the right hand turn and the triangle flashes (this is a 18 yo description). So Im assuming the ABS is engaging now since when it activates I would say a grinding noise.
Old Sep 19, 2018 | 01:55 PM
corsair944's Avatar
2015 C63 Coupe
Videos:
Old Oct 26, 2018 | 08:39 PM
Gavin Viney's Avatar
w210
Check for boost leaks, check earth point behind right headlight
