10x18 wheels could they fit?
would 10x18 alloys fit on the front and rear?
im looking to lower 40mm and will use 35 profile rubber thx |
Re: 10x18 wheels could they fit?
Originally posted by abtex would 10x18 alloys fit on the front and rear? im looking to lower 40mm and will use 35 profile rubber thx As for the tire profile, the "35" you'd mention cannot be considered in isolation. It is a %'age of the tire width which is meansured in millimeters and depending on the wheel width, that changes the width you need/can put on. The actual height of the tire therefore changes with the width of the tire. The wider the tire, the higher the actual profile. Its not that simple ;) |
You must mean 18x10 :)
18's usually need 40 series rubber. I'm using 245/35/19, but on an 8 inch wide wheel. (front). |
Originally posted by The Doctor You must mean 18x10 :) 18's usually need 40 series rubber. I'm using 245/35/19, but on an 8 inch wide wheel. (front). |
Originally posted by Whitey Dang, thats a lot of rubber for 8"..........but I suppose u must need it to beef up the puney 8"..hee, hee:) |
on my 18's i think i run 245 / 60
Originally posted by vraa on my 18's i think i run 245 / 60 But 245/60 on 18's?...that seems a bit out of proportion, no matter what width the rims. |
