99 e320 water under rear seat behind driver ????
Old Jul 17, 2018 | 05:13 AM
TanoMazzi's Avatar
1999 e320
Hi guys I'm new wit MB ,"e320 with 96k miles clean in and out " I just purchased this car from this guy that he have the car park for at least 2 year , I took it for a drive and runs fine , motor sounds good and trans also . I noticed a few issues ac not working at all , fog lights remain on ,so I pull the fuse , headlight not working except for 1 low beam , tail lights also , sunroof not working, radio also ,rear windows not working few more electric issues . But I look under the back seat and I found water ( not on the battery side ) I saw a wire with a connector there that looks wet . I wonder how the water got there and also what can be the issue with this baby Benzy... thanks guy for any help in advance
Old Jul 17, 2018 | 11:08 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Hi, maybe the water is coming from the trunk, can be the door trim. another possibility it is coming from the door, maybe the drains at the door are clogged.
Headlight, fog lights and tail lights with problem can be the headlight switch, better verify it with a multimeter.
Sunroof, maybe it is stuck, you will need a lot of patience and an oil like WD40 to release it, I hope the cable or the engine that moves it is not broken.
For the air conditioner, here we have many topics related to this, maybe one of then can help you.
Best regards,
Sergio
