99 E320 Wagon...No Crank after Dead Battery
I have a E320 wagon that has been parked since last winter with a broken control arm,, I finally repaired that and discovered that the battery was drained. (it was started 2-3 months ago) I charged the battery, (it tested good at AZ after charging, for whatever that's worth),and i'm not getting any cranking at the starter....(I considered crossing the starter over but I read thru some posts on here and thought better of it)..... both key fobs unlock the doors and light up the dash when inserted and turned, just no crank ,I can shift it out of park with the key on,,, but it wont crank in neutral or park...Any ideas on what can cause this and where to troubleshoot 1st??
I've tried jumper cables in case the voltage was low, but it tested good under load, so idk what else to try...the battery is on the sunset side of its life cycle so I am thinking a new Battery is coming tomorrow..
My 1st Mercedes and I'm extremely excited at the prospect of cruisin in it
Thanks, Jeff
The Wife is having surgery in the morning, so I won't get back to it before Sat or Sun,,,,,,wish me (and her)luck,,, we need something to go right for a change
thanks, Jeff
Hope you enjoy your car, most issues are well known as it is an old car, and for both of mine I haven't had any serious problems. I also enjoy how easy they are to work on compared to my GMC truck!
thanks for the reply,,, it turned out to be a bad starter, but after i got it running it had a misfire on #3,#4,#5, & #6 so i changed plugs and switched coilpacks from side to side which switched the misfire to #1, #2, & #3 so i ordered new coils from Ebay for $50/set. it is now running good and CEL is not on.....I also drilled a whole into the Cat converters and rodded them out clean because i was thinking that they were plugged.....now the only issue I'm having is the traction control keeps tripping and I have to turn it off & on to keep the car from losing power when it's flashing the triangle on the dash...doesn't matter if it's off or on when I start driving, it always trips out at around 30mph, it does that 2-3 times then it's all good til I stop & shut the car off, then it starts all over again.....I replaced the ABS module with no improvement so Idk, must be a wheel sensor or something,,,, it's drivable so I'm going to let it ride
Thanks again,
Jeff
