Oil Burning
Old Aug 7, 2018 | 04:50 AM
Orxan_092's Avatar
Mercedes E320 2000 years
Oil Burning
i have mercedes 2000 years E320 benzin had gone 151000 km and last chech in about 7000 km driving oil light show on that check oil level than check it that rod show minimum oil in my car please help me why it could be
Old Aug 7, 2018 | 07:06 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Hi Orxan,
I recommend you to take the car to a mechanic to take a look, it can be can be the bad valve retainer or the engine with slack in the pistons and rings, in the latter case will be the case to rectify the engine.
Usually when you have a bad valve retainer, at the first start of the day is possible to see a bluish white smoke coming out of the car exhaust the stops in a few minutes but, if it a problem with the engine pistons this smoke is constant.
Of course there is a possibility of a retainer gasket og the engine that is worn, in this case you can ser the oil leaking from the engine to the floor.
