Tow light came on
becuase you'd be chasing electrical gremlins. JUST STOP POWERING IT. each time you try to
test and power up a device or appliance, you risk further shorting. disconnect battery and
begin moisture abatement right away. examine closely the fuse cluster beneath the seat. use contact
cleaner liberally and wipe and blow dry. examine carefully and blot and clean out PSE pump within
the foam surround (harder to clean but you must and thoroughly). any relays in that area are now
suspect.
if you don't spend the time now (ASAP) corrosion will set and make it even more difficult to problem
solve.
battery: doesn't matter that the fluid level appears normal. MUST perform density check with hygrometer
followed by a trickle-then-float charge for at least a few days. check specific gravity periodically and log
progress.
you have potentially serious situation but if you get to it quickly, you may be able to salvage it in labor only
or a few dollars. wait....and you'll pay $100/hr for someone else to troubleshoot this.
check the door and roof drains !! i don't think hvac drain is a long shot. under the windshield, within the
engine compartment is another drain in front of the passenger side firewall (near relays cluster). check
that, too ... but i think it's less likely to have clogged. never hurts as a PM check in any case.
r-
you have verified that the foam was soaked. open and blot and definitely blow dry asap. good luck !
