0810 & 0810 (P0410)
0810 & 0810 (P0410)
08 GL450 120k miles: For several months, I've noticed a noise coming from driver's side engine area. The noise sounds like something knocked loose and trapped as it's doesn't always sound the same (as if it's flapping around). I've taken it to several mechanics and no one can find the culprit. Well two days ago my 'check engine' light came on. I have a fault code P0410: 0810 & 0814. Could this be related to the noise I'm hearing? And what's the process to fixing both the noise and fault codes? I want to make sure I have good information to inform mechanic before taking GL450 in again. Thanks in advance.
You are in the E class Mercedes forum. You may want to go back and post this in the GL forum to get a better result.
