Help identifying missing part from fender
The rubber seal that goes in the space marked in red rotted and is missing. Please help me identify the part number.
Both doors have that rubber seal, it's just both fenders that are missing it.
here are some parts diagrams you can navigate with. that area/part should be in GROUP 69
Parts diagrams - russian1
Mercedes Benz EPC Type W210 210 E-Class Information Everything Benz
https://www.benzworld.org/forums/w21...arts-list.html w210 part list
https://www.dropbox.com/s/ur1prhznke...0E320.pdf?dl=0
Russian parts diagrams, PDF, with quick and dirty index. Best utilized if
downloaded and opened using PDF reader then can view index
some parts may be model/VIN specific so you may find the need to consult with
the dealer to get proper color or design match
Try these 2 parts - left and right side, respectively.
A2106987130 & A2106987230
http://mb-teilekatalog.info/view_Sub...=69&subgrp=060
part# 375
do google search too, on the part#s above.
part# 375
Lower Moldingt - about $15 + $2 fastener..
If you don't have EPC and you don't relish surfing a Russian website - use parts.com - then with VIN# call local MB Parts Dept and confirm part # by phone.
Is there a part number for the rubber piece on top of the side skirt? (AMG)
I was told its discontinued but also that it is simply glued on
fabbrisd1, what fastener are you referring to? I found the parts on mbonlineparts.com and I'm also ordering clips for the side skirts as I'm taking the car to body shop to have Rust spots treated.
Some research points that if the body work is done right and the car is kept indoors, the rust does not come back. Other comments say that rust always comes back.
I found a guy who will treat them and repair the hood paint chips for $1200. I'm thinking of just doing it since I really like the car and will keep it for a year or two.
As to how long it takes to bubble back up? Will vary based on the work done and the environment it is exposed to.
GL.
