Any aftermarket suspension parts besides springs/shocks?
Old 02-18-2019, 06:48 PM
Matt300ZXT's Avatar
1993 Lexus SC400
I want to purchase a set of coilovers down the road for my 99 E300 and just curious if anyone makes adjustable camber arms, control arms, stuff like that? I haven't come across anything yet so I just wanted to ask.
Old 02-18-2019, 09:29 PM
SPONSOR
K-Mac's Avatar
Mercedes-Benz CLK 550
For the W210 (and every model Mercedes 1968 to 2019) we manufacture Front Camber and Caster adjustment kits. For the rear Camber (and extra Toe) kits.
OEM there is only front and rear Toe - directional adjustment. No Camber or Caster to allow to adjust tire contact angle. You can fit (front only) inaccurate one offset position fluted bolts.
The K-MAC unique patented design also replaces at the same time the 4 front and 4 rear highest wearing suspension bushings (and providing 4 times the adjustment of these fluted bolts).
Is precise single wrench adjustable - accurately on car under load, direct on alignment rack.
Re - instating from the early '90's precise ongoing adjustment capability to resolve costly, premature edge tire wear and correctly resolve steering pull
The result of day to day commuting encountering high cambered roads, altered height through load carrying or lowering, fitting wide profile tires or curb knock damage.
For the W210 (and most models) have designed with bush extraction tools so can be fitted without arm removal or need for bench press.
Old 02-19-2019, 03:49 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
^ kmac has good stuff. Camber arms are available for our rears. I made my own using speedway motors parts. Also H&R makes swaybars front and back.
Best bang per buck on our cars is some real good shocks. I highly recommend Koni yellows.
Quick Reply: Any aftermarket suspension parts besides springs/shocks?
