Ac climate control
Old May 6, 2019 | 02:52 PM
Rui Martins's Avatar
320cdi w210
Ac climate control
Hello, I have the following values of climate control.
https://youtu.be/w8B-7fFZnbo
Anyone can help me, especially the 7 that is the pressure, is it ok?
Other issue is the left and right vent has different temperature...left seems that there is no cold air, but right is cold as hell.
Old May 6, 2019 | 07:53 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Rui,
Dont be lazy, post your readouts.
Old May 7, 2019 | 02:32 AM
320cdi w210
1- 43
2-38
3-15
4-08
5-32
6-81
7-13
8-60
9-05
10-6
11-2.0
12-4.0
20-2.0
21-0.7
22.00
23-00
Old May 7, 2019 | 03:34 AM
khomer2's Avatar
7 is the pressure in bars. That seems ok.
3 & 4 are your heater core temps - left and right respectively - they should be the same if they are blowing correctly.
Where are your error readings?
Old May 7, 2019 | 06:14 AM
320cdi w210
Thank you khomer,
I have filled the AC system last saturday and few hours later I got the error B1241 - Low freon. I reset the error and then seems it´s fine, except the left core temperature it´s warm and right one very cold.
Probably the car workshop didn´t filled with the correct quantity of freon. How can I check it?
Thank you
Old May 7, 2019 | 10:00 AM
khomer2's Avatar
Originally Posted by Rui Martins
Thank you khomer,
Thank you
They refilled with Freon?
What year is your MB?
Please update your user CP info to include your w210 year.
MBs since 1991 used R134a refrigerant.
Old May 7, 2019 | 10:22 AM
320cdi w210
They refilled with R134a
Its a 320CDI from 2000.
Old May 7, 2019 | 10:32 AM
khomer2's Avatar
Check the sticky's for "Duo valve". This valve controls the coolant going to each side of the heater core. Possibly, one side is stuck and keeping the heater core hot all the time, even when AC is on.
Duovalve Removal and cleaning
Did your car shop check for leaks with UV dye at all when they refilled?
Old May 7, 2019 | 10:39 AM
320cdi w210
Thank you I will check. They did a pressure test in order to check the leaks and everything was fine. They did a test like 2minutes after the refilling and both heater cores were cold. But after some hours I got that error of low R134 (EC light always red). After reseting the AC it´s only working for the right side...
For me is that they refilled the R134 with incorrect KG.
Old May 7, 2019 | 11:55 AM
khomer2's Avatar
ok so that's good they tested the pressure, but for how long was the pressure test?
You can still have a possible (slow) leak somewhere?
But check the link provided first, and do a search and read up on the past threads related to this "no ac on left side". Do the simple checks/tasks first to see if it resolves your issue.
Old May 8, 2019 | 02:31 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
You can spend weeks dropping parts in the system, or you can spend 90 seconds to troubleshoot it.
http://www.mercedesmedic.com/ac-air-...le-codes-list/
Come back with 2 sets of reading per the site and attached notes.
