Advice On 722.6 Transmission
Old May 28, 2020 | 01:13 AM
Dave The Hippo's Avatar
2002 Mercedes E430 4Matic
Hello all, I am writing to you guys today because I want to do a transmission fluid change on my car. It is at 140K miles and i do not know when it has been changed and to replace the transmission control connector. When I use the dipstick to check the level, it is a little lower than normal but what is very confusing is that the fluid inside of it is green. I looked into all of the fluids compatible for the transmission and not one turned out to be green in color. I really do not want to put the new fluid in and have a half and half concoction going on in there. Has anyone had a similar issue or experience, because I just need another viewpoint. Thanks in advance!
Old May 28, 2020 | 03:59 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Dave,
imo, I would do a flush.
Here----------> Everything you need to know in the sticky under T
Old May 28, 2020 | 09:03 PM
Honestly I agree with you. I looked up a video and it does not seem that complex. I looked up a video and it shows the best way of flushing to loosen a line to the cooler and run, fill, repeat.
Old May 28, 2020 | 09:12 PM
khomer2's Avatar
Just so you know
https://www.benzworld.org/threads/wh...fluid.2872417/
Old May 29, 2020 | 12:09 AM
That was one of the articles and honestly it was pretty all over the place. In the end, I cannot find green fluid for my transmission so I think the only option is to flush it.
