Bulb advice
Old Jul 28, 2020 | 12:22 AM
dadof39's Avatar
1999 E320 Base, 2022 GLC300W4
Bulb advice
Apologies if I'm starting a new thread for an old topic, but I'm trying to find the specs for a replacement bulb for the passenger footwell courtesy lamp. I have a 2002 E320 Base Sedan. Many thanks.
Old Jul 28, 2020 | 06:32 AM
PortAxePlayer1's Avatar
'97 E200, '06 E350 & '23 E350
Hi,
This is the part number for the footwell ambient light lamp. Plenty of options if you Google it.
A 220 820 11 01
Old Jul 28, 2020 | 10:51 AM
dadof39's Avatar
Thanks. That appears to be the lamp assembly. Do you know the specs on the bulb that it holds? This is my dilemma.
Old Jul 28, 2020 | 11:32 AM
raymond g-'s Avatar
99 E320
why not just pop the bulb out and take a look. by the way, when I plug the p/n provided above, I see this
it's possible that the bulb is used in more than one location
Old Aug 1, 2020 | 03:43 PM
dadof39's Avatar
Because the bulb is missing and I need help with the replacement P/N
Old Aug 1, 2020 | 04:49 PM
raymond g-'s Avatar
99 E320
oh, that makes sense. If you're lucky, it uses a bullet bulb in which the lamp socket is about an inch apart.
If you see that this is so, you get a little wiggle room. Just measure the distance between the contacts right
at the center (where the pointy bulb ends would be secured) and add a millimeter or two for tension.
you have the option of replacing filament bulb or LED.
my 1999 does not have this feature so I am unable to measure what would be there for facelift w210
File Type: pdf
Old Aug 1, 2020 | 05:39 PM
dadof39's Avatar
That is an outstanding document, thank you!
Old Aug 1, 2020 | 05:59 PM
raymond g-'s Avatar
99 E320
hope it helps in some way. if you ever find out the bulb number, be it an MB part # or a generic number, let me know and I will add it to that document. r-
Old Aug 7, 2020 | 11:26 PM
raymond g-'s Avatar
99 E320
dadof39: unless you have some oddity, that part number DOES reference the bulb. it is a bulb/socket combo as far as I can tell.
the wiring terminates at a female pigtail and the socket/lens/bulb is all one unit under the glove box.
you may have figured it out by now
