Trim source and seat question
Old Mar 11, 2021 | 11:14 PM
Zhoolka's Avatar
2016 Metris, 2015 G550, 1981 300D, 1981 300SD, 1987 300SDL, 1991 300D, 1983 240D
I wonder if someone here knows sources of trim pictured above. I need it in beige for my 1999 E320 Wagon. Would be grateful for tips on places selling used trim, could not find any on ebay.
Also, when I try to adjust passenger seat, it only moves forward no matter what direction I move the adjuster on the door. The only way to get it back is to use memory button. If I push the adjuster backwards the seat still goes forward! Problem with the door adjustment assembly or should I look anywhere else before attempting to replace? When I push the adjuster forward - the seat goes forward too as expected.
Thanks!
Old Mar 12, 2021 | 11:58 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Your local PnP - row52.com
For your memory seat button, remove and use some electrical contact cleaner. It may just be a build up of dust debris inside the controls.
Report back after cleaning and testing.
