clear something up. 99' to a 00+ taillight
Old Oct 5, 2004 | 03:57 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Don't use a heat gun--you'll probably end up warping the lights before you get the correct fit. Use the Dremel. If you don't have one, it's worth buying--ony $30 or so.
Yes, if you are an idiot, don't use a heat gun. If you are not, the outcome will be much much better than grinding the material. The plastic will bend very easily with a heat gun. The other benefit is that your rear lenses stay sealed with the heat gun vs the gaping hole caused by the dremel at each corner that was shaved.
