My w210 get cooler
Old Jul 22, 2023 | 09:49 PM
H danielle's Avatar
E240 w210 year 2000 v6 2398 c.c
My w210 engine coolant get cooled ?
My car is w210 ,2000 facelift E320, when I turn on the climate control on front windshield defrost , it blows very hot water on front windshield , if the engine temp indicator is at 95c , it gets down it to 85c , it's great but how this happens and why ? And another question please , how can I turn on coolant fan through climate control without turning on the AC just front fan , i heard it is possible ?? Waiting ur answers thanks.
Old Jul 23, 2023 | 04:30 AM
H danielle's Avatar
Old Jul 23, 2023 | 04:34 AM
H danielle's Avatar
hello guys , please I need answers , waiting you..
Old Jul 23, 2023 | 02:15 PM
raymond g-'s Avatar
99 E320
I have many more questions than answers but my first thought is if the heater/fan is blowing water onto the inside of your windshield, the heater core may have sprung a leak and blowing coolant, or, a drain hose is clogged.
Old Jul 23, 2023 | 03:38 PM
H danielle's Avatar
Originally Posted by Plutoe
My thoughts exactly!!
However if you are talking about the aux fan and turning that on---you cant---its turned on when coolant temps exceed default software settings----or WTF are you talking about
I mean this button gets the engine temp gets down..
Old Jul 24, 2023 | 04:24 PM
H danielle's Avatar
Hey guys I need answers please ???
Old Jul 26, 2023 | 02:54 AM
H danielle's Avatar
Before
Old Jul 26, 2023 | 02:55 AM
H danielle's Avatar
After
Old Jul 26, 2023 | 04:56 AM
H danielle's Avatar
Sorry i mean blows a hot air not a hot water..
Old Jul 30, 2023 | 01:52 PM
raymond g-'s Avatar
99 E320
when you press the defrost button, the fan turns on HIGH, the climate control directs most of the heater air to the windshield. so it sounds as though it is working as designed.
if you only want ambient temperature fan assisted air (not hot air....not AC cooling air but just like outdoors temperature air) simply turn adjust the "-" or "+" and adjust the temperature lower...but not "LO" (which activates the AC)
https://www.carmanual.org/OwnersManu...nz_e-class.pdf
Old Jul 30, 2023 | 02:52 PM
raymond g-'s Avatar
99 E320
(further thought)
that will draw outside air into the car as non-AC ventilation. be sure you don't press the button to the RIGHT of the defrost button. That has the picture of the side of the car with a curved arrow in the middle. That closes baffles so that outside air is not drawn in by the fan... and the fan only recirculates cabin air (which could get stale). When might the recirc air button be used? when you driving past a farm and the cows are saying hello to you in a smelly way. In such instances you may also consider activating the charcoal filter feature
