How do you remove the rear seat?
I have a rattle in the rear deck lid by the speakers, that wont go away. I need to take some time and make sure everthing is tight. My main problem is removeing the rear seat. I have removed the bottom part before when I connected my amp to the cars battery. Does anyone have any pointers or diagrams?
Thanks Mario |
For the bench, just pull the to little fob (one on each side of the seat), and pull the seat up. Once it's up, you'll see couple screws, untight them. Remove the headrest by pulling them straight up, then you can take out the back rest as well.
Thanks Mario |
The rattle might actually be one of the stock subwoofers in the rear deck. Do you hear the rattle with the radio off?
removing the headrest on the back seat...
...I'm able to remove the back rest of bench for the rear seat....BTW mine has 3 screws 1 on each end and another 1 in the middle, just below the first aid kit. My Question is, How do I remove the headrest...I remove the series of screws..and the headrest didn't come out.... Has anyone done this before....I know few peeps have replaced their rear deck tray to the newer look...PLEASE HELP cheers! |
D2Benz,i wanted to upgrade to the longer third brake light as well,since i'm upgrading my tail lights to the newer LED type. My question to you is where did you get the rear shelf from? Please reply or PM me...Thanks
Ruffrob,
Believe it OR not I got it from a scrap yard (junk yard) in Atlanta and had it shipped to MD. Its been a long road for me....I call around to different junk yard s occasionally and one junk yard place did a search on their network and found it in ATL......next 4 me is the 2000+ rear bumper...I've been looking for about 2 months seriously.. PLEASE HELP!!! on how to remove the head rest..... cheers!!! |
E55 cent, did you fix your rattle? I'm having a problem with a rattle from the rear deck and I can't figure out where it is. It's driving me crazy.
Thanks. |
I'm having a rattle as well,having just installed a pair of JL Audio 12" subwoofers,and an Alpine amp. Please let us know what you've found....Thanks
I fixed the rattle a while a go. Most of the noise was coming from the rear sunshade, it was not going down all the way and was a little loose. I also removed all the foam from in the rear deck so I would get more bass into the cab of the car. Since I removed all the insulation, I replaced it with Dynamat to keep all the rattle down to a min. I dynamated the top of the metal deck and the underneath of the deck lid cover.
Now I have much more bass and zero rattles. |
