E-Class (W211) 2003-2009
OEM Navigation Retrofit w/ pics
Old Oct 8, 2011 | 05:57 PM
  #326
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2012 E550 coupe (sold), 2017 C63 sedan (sold), 2018 C63S Coupe
Installed my nav successfully this weekend. Thanks to anyone who has contributed to this thread, it made the install super easy. Just to add my 2 cents to the thread:
If you are planning on pulling up the passenger side entry way to access your MOST ring, the fiber optic cable w/o the sheath will be easily visible, the fiber optic cable w/the black sheath is actually run pretty far up into the cabin. It will look like its running up to the head unit, it is not. However it is taped to another bundle of wires, just remove the tape and pull it toward the back seat. Then just connect the fiber optic cables labelled 13 and 14, plug the other two together (16XX and 20 I believe, but it doesn't really matter as when you plug 13 and 14 together the other two cables left just need to be plugged into each other). Then viola, ur now tapped into the most ring.
OEM Navigation Retrofit w/ pics-img_0779.jpg
OEM Navigation Retrofit w/ pics-img_0780.jpg
OEM Navigation Retrofit w/ pics-img_0781.jpg
Thanks again for the great info
Old Oct 24, 2011 | 09:41 PM
  #327
Yenu S's Avatar
Thank you steph for the info really helped, it only took like 30 mins and it works great now thanks very much. We got the parts from MB dealership, we and got the drive locally for cheap.
Old Apr 10, 2012 | 08:27 PM
  #328
ursacat's Avatar
E350
Installation of OEM Unit into 2007 E350
Great Instructions.
I'm about to embark on a similar project to install an OEM Unit (eBay - $350 w/ Disks) into my wife's 2007 E350 Sedan. If I don't do it right it's divorce court. So do you think the install is similar to this thread or should I look elsewhere? I took the little panel off the pass side trunk compartment and it looks like there is a 1 plug (fits exactly into the unit) and 1 fiber optic (blue)plug / black cable that also plugs right into the unit although the other end of this fiber cable isn't plugged into anything. I have not taken the trunk cover off yet.
Thanks in advance, Lou
Old Apr 10, 2012 | 09:13 PM
  #329
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Originally Posted by ursacat
Great Instructions.
Passenger side? Did you mean to say driver side?
Old Apr 10, 2012 | 11:54 PM
  #330
ursacat's Avatar
E350
Yes. Stupid me. Drivers side rear panel of course. Thanks
Old Apr 12, 2012 | 03:34 PM
  #331
ursacat's Avatar
E350
Install Update
Hello, My local MBZ Shop Forman gave me the MBZ Installations Instructions (although the initial post here is quite a bit more detailed) Here are the part numbers for the installation kit (less the Navi Unit.) I can order these of course from the dealer unless there is another known source?
Antenna Splitter - A210 820 24 89
Bracket, Base - A211 540 68 33
Bracket, Car Navi Processor A211 545 63 40
Panel, Trunk, Left Side A211 690 01 53 9C53
Thanks, Lou
Old Apr 12, 2012 | 03:42 PM
  #332
Mackhack's Avatar
Screws and bolts are missing on your list to complete the retrofit.
Old Sep 9, 2012 | 04:09 PM
  #333
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Any pictures of the location of the loop connection that needs to be done near the B-Pillar on the driver's or passenger side? My car was pre-wired in the trunk and had the wires zip tied out of the way. Plugged those into the nav drive but still says unavailable on the command unit. Maybe it just needs programmed via STAR? Thanks in advance.
Aaron
Old Sep 9, 2012 | 04:26 PM
  #334
Mackhack's Avatar
Aaron
The orange fiber optic cable is underneath the plastic cover that covers the cable channel NOT beneath B-Pillar.
Yes you have to version code your MOST ring to and CI.
Old May 10, 2013 | 08:00 PM
  #335
Grree's Avatar
2004 E320 Wagon
Sorry for digging old treat.
I found in a trunk set of connectors, I'm not sure is this for navi unit? If yes, what else needs to be done to make navigation works? Thanks!
1 is GPS connector, one end going to the roof while another end with all set of wire (2,3,4 and 5) going somewhere to the front of the car, so blue connector not from GPS or it has a splitter in a front? And just curious what for cable 5?
w211 2004 Wagon with Logic 7
Old May 10, 2013 | 08:32 PM
  #336
Mackhack's Avatar
Yes, your car is pre-wired for OEM navigation system.
Old May 10, 2013 | 11:23 PM
  #337
Grree's Avatar
2004 E320 Wagon
Thank you for fast reply!
All what I need just connect nav drive or something else do with fiber optic, splitter, etc? And do you know what is cable markered 5 on the pics? Thanks!
Old May 11, 2013 | 01:14 AM
  #338
WHTEVO's Avatar
Yes, those connect to the nav drive. #5 goes to the antenna splitter up higher attached near the c-pillar. Don't forget you need to complete the fiber optic loop under the door sill area as well.
Aaron
Old May 12, 2013 | 11:51 PM
  #339
Mackhack's Avatar
You need an antenna splitter, mounting bracket, base bracket, nut, screw, new trunk panel.
Old May 20, 2013 | 07:11 PM
  #340
Grree's Avatar
2004 E320 Wagon
sound interruptions
I installed, everything works, thanks for helping me! But I got some issue. Sometimes sound is interrupted for about 2-3 second and next continue again normally. Doesn't matter I listening MP3 or radio. Also when in navigation mode and sound being interrupted, I see on screen map hangs and thereafter route is recalculated.
My car from 2004, navy unit comes from 2006 E-class. Both Comand and Nav drive is up to date. Where needs to dig? Fiber optic not kinked, I watched this, problem with nav drive or just needs version coding? Thanks!
Old May 20, 2013 | 07:58 PM
  #341
Mackhack's Avatar
Could be a damaged graphics chip on the COMAND front panel's display. Had one like that a few months ago on someone's COMAND after we retrofitted navigation system.
Old May 20, 2013 | 11:53 PM
  #342
Grree's Avatar
2004 E320 Wagon
But how I can damaged it, I even didn't touch a Comand at all and before retrofit all was good. Also I noticed navigation didn't always start, I see just spinning circle. Needs to reload DVD disk or sometimes help turn ignition and comand off and back on. But this I think related to my bad copy of original disk (I have both and original disk doesn't read at all)
Old May 21, 2013 | 06:45 PM
  #343
Mackhack's Avatar
You didn't damage it. The device is old and it might go bad. Electronic components do get bad believe it or not. And the same symptoms we had with another COMAND a few months ago. He bought a new (used) one off of eBay, replaced it and problem was solved. You don't have to believe me nor do I say I'm 100% correct with my suggestion of what could be wrong but I'm pretty sure.
Old May 24, 2013 | 09:42 PM
  #344
Grree's Avatar
2004 E320 Wagon
How do you determine that this is a graphic chip? I'm asking because instead of buying an expensive Comand I can replace just the chip, I have some skills and equipment. Also I would like to tell that the sound is interrupted each 6 min exact! Is this GPU behaviour? Thanks!
Old Sep 29, 2013 | 03:47 PM
  #345
noud's Avatar
99 E55, 00 S500, 01 CLK55, 01 E320, 04 E320
Hi, I have 03 E500 with Audio50. Today I just plugged in Navigation Screen, and it is working fine but no navigation because i didn't connect DVD drive. But i have few questions:
1. What is second plug on navigation screen next to optic connector? What i should plug there?
2. In menu it shows AUX. what should i do and which parts do i need to make it work?
Old Sep 29, 2013 | 04:20 PM
  #346
Mackhack's Avatar
Check your clove compartment upper edge! There is a 3.5 mm connector. Plug audio source in and press aux soft button on COMAND to change to aux source.
Old Oct 3, 2013 | 11:33 AM
  #347
murman's Avatar
Sounds like he needs to install the aux cable first. They aren't pre-intalled for cars with Audio 50, IIRC. I had to add it to my car when I swapped an Audio 50 for a COMAND.
Old Oct 4, 2013 | 05:00 AM
  #348
noud's Avatar
Yeap, I see spot for the plug but it is sealed. I tried to find this AUX cable to connect but didn't find any info, where and how to connect, part number, i didn't even find picture!
Old Oct 4, 2013 | 08:50 AM
  #349
Mackhack's Avatar
Sorry but you're plain and simple lazy: it took me less than 3 seconds to find pictures, part numbers and instructions of how to retrofit it using good 'ol google!
http://lmgtfy.com/?q=w211+aux+input+part
Old Mar 3, 2014 | 08:00 PM
  #350
mauromora's Avatar
Mercedes E320 W211 2004
Sorry to bring back this issue again.my car is a E320 W211 from 2004 (mf.feb/2004) I have the Radio 50 APS with Harman Kardon audio. My question is if all this steps apply to my car or because the HK audio I can't do this upgrade? Thanks in advance
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
