E-Class (W211) 2003-2009
Antennas by New York Times (long)
Old Mar 15, 2005 | 12:18 PM
Oslo's Avatar
As Cars Become More Connected, Hiding the Antennas Gets Tougher
By IVAN BERGER
Published: March 14, 2005
IT makes sense that automakers borrow model names from the jaguar and impala to evoke speed and gracefulness, yet carefully avoid associating their products with a creature like the porcupine. But with all the antennas in some new cars - high-tech luxury sedans may carry 18 or more - it takes a major engineering effort to design vehicles that do not bristle with metal quills.
Advertisement
Today's cars need a selection of antennas just to serve their entertainment systems (separate units for broadcast and satellite radio, and another to receive television programming); navigation units and cellphones use different aerials again. The count increases further with systems that employ a "diversity" antenna to improve reception. This design uses two or more individual antennas tuned to the same band, relying on a microprocessor in the radio to select the clearest signal.
More antennas yet are required for cars equipped with telematics systems like OnStar or the Mercedes-Benz TeleAid. These systems offer concierge services and emergency notification in the event of a collision, using a second set of cellphone and global positioning satellite aerials to contact a call center.
Keyless entry, security alarms and other functions controlled from the driver's key fob require one or more antennas, as do the short-range Bluetooth communications that link a driver's cellphone or handheld computer with the audio systems of some new cars to permit hands-free phone conversations. Direct-reading tire pressure monitors necessitate still more aerials to keep tabs on the inflation of each tire, including that of the spare in the trunk.
Active cruise control systems, which maintain a preset distance to the car ahead (and can apply the brakes if the gap narrows too quickly), depend on a radar antenna mounted in the grille. Bumpers may carry a series of antennas that emit signals to measure the distance to nearby vehicles as part of a warning device intended to make parking less of a hit-and-miss affair.
Each feature making use of a radio frequency input requires an antenna tuned to its particular signal, presenting a big challenge to the engineers who must find places to install all of this hardware. Adding to the complexity is a wide range of size and shape requirements, which change with the wavelength of the signal.
Besides avoiding stickleback styling, incentives to strip antennas from the car's exterior and tuck them away include the potential to reduce wind noise and aerodynamic drag. Drivers also appreciate the elimination of breakage by carwashes and vandals.
Some of the earliest antennas in cars were wire loops hidden within the cloth tops of 1930's sedans, but with the advent of all-steel roofs the upright mast antenna became the preferred design. About 30 years later, carmakers tried hiding them again, integrating antennas into windshields or rear windows by applying wires to the surface or embedding them inside the glass.
"Those were simple antennas, and reception was poor," said Robert W. Schumacher, manager for integrated media systems at Delphi, a leading parts supplier.
Recent designs use an embedded metal film of tin oxide - thin enough to be transparent - that can be electrically heated for defrosting, said Eric Walton, a research scientist at Ohio State University whose designs are used in some General Motors cars.
Carmakers also hide antennas behind plastic panels that will not block signals, and in bumpers, parcel shelves, trunk lid trim, doors, under dashboards and in roofs.
For its PT Cruiser convertible, Chrysler is experimenting with antennas in the roll bar. Mercedes-Benz puts the antennas for its keyless-entry system in the doors, center console, bumpers and windows.
Antenna modules can also be concealed in outside mirrors, Dr. Schumacher said. In a pinch, several antennas can be combined in one compact housing.
Most of the new antenna types, Dr. Walton said, are "conformal" antennas, which follow the contours of the car so that "the entire car becomes the antenna." This design became possible only with the availability of computers that could calculate antenna performance for the curves of cars not yet built.
Properly aiming conformal and concealed antennas can be tricky. With early windshield antennas, for example, "you'd turn a corner and the station would disappear," Dr. Walton said, a problem solved by installing window antennas on all sides of the car. "We have to deal with the geometry the car designer gave us. Antenna engineers would prefer shaping cars to be effective antennas, but those would be some pretty funny-looking cars."
If the car's body panels are isolated from one another, they can be pressed into service as multiple antennas for diversity reception. Phase diversity systems, a design coming soon to some DaimlerChrysler cars, add together the signals of several antennas to make them stronger. These systems can also be configured to work like a single antenna that electronically stays aimed squarely at the signal source, even as the car turns.
The number of antennas aboard cars is expected to increase further with the spread of wireless broadband services.
One maker of audio systems has proposed music downloads from home computers to a car parked nearby, using a high-speed wireless connection, and Mercedes-Benz has demonstrated a concept it calls drive-by infofueling, in which navigation and information systems can be updated at a toll booth or gasoline stop.
Will this forest of antennas doom the public to driving porcupines? No, cars will maintain the sleekness of dolphins - designers and carmakers prefer it that way.
