Need some help on Mud-flaps/splash guards for W211
Please provide some input on the above subject. After 2 attempts on purchasing some mudflaps for my E320 (first set were for a W210) I finally got a set that fit, so I thought. The rears are ok, but the fronts have a gap, and looks like they are designed for a car with the sports package. These are the part numbers I have: Front- 6-6-52-8214 Rear 6-6-52-8215. Also I noticed (since I had the wheels off a few times) the Car has 23K miles and the front pads look fine, but the rear look like they are half way worn. Does this seem to be the norm?? Thanks for you inputs :nix:
Davel,
I installed the mud flaps on my non-sport W211. My front set fits much better than the rears. The fronts really fit as they were intended but the rear still has a small 1-2 mm gap at one point. Unfortunately I don't have the part numbers any more. Jim |
If you do a search on this forum you will find all the information, pictures that you need. Good luck, John |
2006 E320CDI Front MudFlaps
Classic and Elegance same front. Avantgarde mud flap is different. Sedan and wafon rear is different.
Originally Posted by whkjr4
(Post 5702242)
Front MudFlaps for a 2006 E320CDI
