E-Class (W211) 2003-2009
E55 Brakes on a E500??
Old Mar 7, 2007 | 03:48 AM
gmotoring's Avatar
2016 G63
Originally Posted by MARK CUMMINS
Yes I Did The Work myself...Its Not that hard..With The Correct Tools!
One Can bleed the brakes without using the star....Just cycle the sbc pump...
Open a door or pump the brake pedal to cycle the pump....Used OE MB Brake fluid
I Checked for any codes and None were found
Mark
Any issues yet? I hope all is fine on the swap? As I just finish the E55 brakes swap to my E500. Lots of work but man it looks cool. I used the motive power bleeder and it works like a charm. so far after a 2 mile drive no fault codes.
Old Mar 7, 2007 | 04:04 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Btw I Will Be selling the LARGE Front Brakes Calipers/rotors/pads with 7K on them (AMG) to Install a set of the 030 LARGER front AMG Brakes on the wifes car PM If Interested
...no you won't...the 030 rotors are only 380mm - you will get the SL65 brakes which are 390mm...
greetingz,
Old Mar 7, 2007 | 11:50 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
greetingz,
OOOOOOOOOppps My bad...Ok SL65 Brakes
Old Mar 7, 2007 | 11:52 AM
Originally Posted by gmotoring
Mark
No problems..NO Fault Codes... Even The Wife said WOW the Brakes are Sooo Much Better stopping! She has 5K on them and NO problems
Old Mar 7, 2007 | 12:22 PM
phatmitzu's Avatar
2005 E55
I have a set of W211 E55 brakes for sale if anyone's interested.
https://mbworld.org/forums/classifieds/181327-fs-w211-amg-brembo-brakes-calipers-rotors-ss-lines-2-000-pix.html
Old Apr 1, 2007 | 04:48 AM
gmotoring's Avatar
2016 G63
[QUOTE=MARK CUMMINS;2061870]No problems..NO Fault Codes... Even The Wife said WOW the Brakes are Sooo Much Better stopping! She has 5K on them and NO problems
Mark
Did you do the 4 piston rears too? Was that just a striaght forward swap? I got the rears and ready to add the four piston rears.
Old Apr 2, 2007 | 12:08 PM
  #32
[QUOTE=gmotoring;2113170]
Mark
The brakes are Upgraded to the 390MM Front with Eight piston calipers
Rears have the four piston Calipers with matching rotors ...The larger Front Brakes Require 19s for clearance
The Brake Upgrade was done without any Problems...all OE MB Parts used
If You are NOT Sure on what you are doing PLEASE have a MB Tech Do the Work...As SBC Brakes are Not a Item to (PLAY) with!
Old Apr 2, 2007 | 01:58 PM
  #33
phatmitzu's Avatar
2005 E55
Mark
My shop did my Brembo swap without sweat. PM me if you need someone for the install.
BTW, AMG brakes are still for sale.
Old Apr 2, 2007 | 07:56 PM
  #34
topdaytrader's Avatar
nice... how much?
Old Apr 2, 2007 | 08:07 PM
  #35
phatmitzu's Avatar
2005 E55
Originally Posted by topdaytrader
nice... how much?
2k OBO. All four corners. Calipers, rotors and brake lines.
Old Apr 2, 2007 | 09:56 PM
  #36
gmotoring's Avatar
2016 G63
[QUOTE=MARK CUMMINS;2115671]
Thanks Mark
I did the front already, I actually drilled the stock spindle to accept the larger 14mm bolts that bolt the caliper mount to the spindle.
As for the rear, I wondered if you had any tips before I began the job.
Old Apr 2, 2007 | 10:35 PM
  #37
[QUOTE=gmotoring;2116951]
Thanks Mark
Its Bolt on also....Other than the rear dust shields/Backing plates
are different than the stock NON AMG set up.....
Old Apr 3, 2007 | 10:19 AM
  #38
ATS's Avatar
ATS
2004 E500 / 2001 C240
[quote=MARK CUMMINS;2115671]
I am sure they only require 18's for clearance as the original e55 had 18 AMG wheels.
Old Apr 3, 2007 | 11:17 AM
  #39
[QUOTE=ATS;2117880]
The Fronts on the Wifes car are NOT the stock E55 Size...
SL65 brakes which are 390mm... That Require 19s as do the 030 Option Cars.
Old Apr 3, 2007 | 03:37 PM
  #40
tpliquid's Avatar
too poor now
thaat is why i scared of working on me moms car. but i have no problem working on my dads 07 E550 kekekekkekekeke do mei
Old Apr 18, 2007 | 11:29 PM
  #41
hbamark's Avatar
2003 E500 Sport
Originally Posted by jameson75
Instead of getting the E55 brake setup, why don't you get the Brembo brake kit. Its probably better than the E55 setup, since the bremo's will be made for the E500, instead of trying to get an E55 setup to fit on an E500. You'll most likely end up paying less for these aftermarket brakes versus paying a dealer to buy the E55 brake set.
BTW, "dropped" you mentioned that you are rolling on 20"s. I am considering putting 20's on my E500 as well, what kind of wheels are you on? Do you have any issue of rubbing or any other problems?
Aren't the factory E500 calipers made by brembo?
Old Apr 19, 2007 | 01:58 AM
  #42
cicbenz's Avatar
1973 Yugo
I'm pretty sure only the AMG brakes arew made by Brembo
Old Apr 19, 2007 | 07:26 AM
  #43
hbamark's Avatar
2003 E500 Sport
I haven't done the brakes on my E500, but they look real similar to my wife's ML500's brakes (front calipers only). I noticed the Brembo stamp inside her calipers when doing her brakes.
