E-Class (W211) 2003-2009
Just greenfiltered my E500.
Old Aug 4, 2005 | 03:19 PM
AMGod's Avatar
Thumbs up Just greenfiltered my E500.
Throttle response is markedly improved. Not even a thousand miles on it, but the ECM seems to have adapted nicely to the more aggressive driver inputs. This is a must do modification, IMHO.
Old Aug 4, 2005 | 04:07 PM
LIONHEAD's Avatar
'06 SL65
Nice....I had to get rid of my high flow airfilters as it blew a MAF on the W211.
Old Aug 4, 2005 | 04:22 PM
vraa's Avatar
I honestly don't know why Mercedes doesn't do this filter on stock cars!
I'm not trying to say this in a mean way, but you're just another one who has had nothing but praise for Greenfilters!
Old Aug 4, 2005 | 04:41 PM
jazzphile's Avatar
2005 SL500, Black on Stone
Does this require that you change one or both filters? I have an '05 E320 and from what I understand, there are two filters. Help?
Also, do you think it's worth doing on an E320? Will I feel an increase in responsiveness?
Thanks.
Old Aug 4, 2005 | 04:51 PM
vraa's Avatar
http://euroteckmotorsports.com/index...50&product=128
There you go You will feel a big difference in throttle response.
Old Aug 4, 2005 | 05:03 PM
jazzphile's Avatar
Ricky,
Thanks for the link. I can get the filters cheaper elsewhere. Are both filters the same? Green Filter number for the E320, far as I can tell, is part number 2247.
Old Aug 4, 2005 | 05:12 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Do you have to put on oil on these filters? I just don't want a problem with the MAFS.
Old Aug 4, 2005 | 06:04 PM
AMGod's Avatar
They come lightly oiled and seal much better than K&Ns. They have been shown not to foul the the hot wire in the MAF like K&Ns in other german vehicle applications.
Old Aug 4, 2005 | 06:06 PM
AMGod's Avatar
Thanks.
These flow so well, you are bound to notice the throttle response and the increased subtle intake growl and you do need two.
Old Aug 4, 2005 | 06:29 PM
jazzphile's Avatar
AM God,
Did you replace both filters?
Thank you,
Jazzphile
Old Aug 4, 2005 | 06:31 PM
jazzphile's Avatar
AM God,
Nevermind....just saw your final post.
Thanks!
DK
Old Aug 4, 2005 | 06:32 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
I am ticked off that they don't have them for the CDI... I emailed them and they first came back and said yes, that there were two filters, then they re-read my email and noticed it was a CDI and said they did'nt make them. Ticks me off! They're really supposed to work great.
Old Aug 4, 2005 | 06:47 PM
AMGod's Avatar
Try K&N's website and use the cross reference tool. I then took the K&N number and crossed the number at greenfiltersUSA. They didn't list them for the E500 there, but I found the greenfilter number for a matching filter and ordered those. It may be worth a shot.
Old Aug 4, 2005 | 07:29 PM
vraa's Avatar
Can you PM me the place where you get them cheaper at? I'm interested if you don't mind
Ricky,
Old Aug 4, 2005 | 08:00 PM
jazzphile's Avatar
Ricky,
You have a PM.
I still can't decide whether to do this or not....don't want to mess up the MAFS by replacing stock filters, and am not sure whether it will foul things up.
DK
Old Aug 4, 2005 | 08:02 PM
vraa's Avatar
I responded back to your PM. Thanks for the heads up! I'll look into it.
I say go for it. You can always clean out your MAF (not suggested for those weak of heart... )
As far as I know, no one has reported problems with the Greenfilters, however I have heard of problems with K&N's.
Old Aug 4, 2005 | 08:44 PM
jazzphile's Avatar
Ricky,
Prices are about $42 at the second site.
For others out there, here are two sites that seem to have pretty good prices on the Green Filters.
Jazzphile
http://www.performance-air-filters.c...ter~parts.html
http://www.autoanything.com/products...ters&p_id=2101
Old Aug 4, 2005 | 09:02 PM
CE750's Avatar
Thanks, turns out K&N doesn't make one either. My best bet is to find ifa German firm makes a good after market filter, the Diesels are a plenty in the EU.
Old Aug 5, 2005 | 10:33 AM
jazzphile's Avatar
I heard back from Green Filter's customer service. The E320 gas version takes two of the part number 2247 filters.
Regards,
Jazzphile
Old Aug 5, 2005 | 12:06 PM
JWS3's Avatar
2004 E500
If these filters are so great then why aren't they std from the factory? Also (m)
if something goes wrong what about warranty issues? I recall reading somewhere reputable that aftermarket filters often allow much more dirt into the engine.
Old Aug 5, 2005 | 12:24 PM
ATS's Avatar
ATS
Yeah this is what I am thinking to, it allows more air in at the expense of filtering. This is kinda' why I am reluctant to do it.
Old Aug 5, 2005 | 12:39 PM
LIONHEAD's Avatar
'06 SL65
From my understanding when I blew my MAF was if the aftermarket air filters caused it, I will need to pay for the repairs.
Old Aug 5, 2005 | 02:46 PM
AMGod's Avatar
Without micron size data related to filtration, it is only an asumption. MAF's have historically failed secondary to over oiled aftermarket air filters coating the hotwire in the MAF itself. This renders the sensor useless to determine the proper fuel to add to the metered air usually causing an over rich mix and rough idle, if any.
