E-Class (W211) 2003-2009
Pic of wiper insert
Old Dec 13, 2005 | 08:19 PM
X72's Avatar
X72
Honda Accord
Pic of wiper insert
Yes, it is possible to replace the wiper inserts on your W211. I used the Lexor Type A inserts which are long enough (must be trimmed to size) and narrow enough to easily slide into the narrow groove on the blade. Tug on the insert; one end slides easily and the other end does not. You want to work on the end that does not slide easily; that is where the insert is fixed with a metal tab. Pry off the plastic end cap with needle nose pliers. Some force is required, so be careful not to hurt yourself. Bend up metal tab. Remove old insert. Replace insert and repeat steps in reverse order until you are done. Good luck. Oh, by the way, these inserts cost me about $5 for the 2 inserts at Wal-Mart. Another poster on this board said he used the Michelin inserts (required lube to get them to slide in) for a bit more money. This won't solve the chattering problem. There is TSB on that where the wiper arm must be bent to the correct angle.
William
2003 E320
Old Dec 14, 2005 | 12:50 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Thanks for the info and pics..
Old Dec 14, 2005 | 08:06 PM
rayray64105's Avatar
'03 E500
William
2003 E320
I'm the one that posted on using Michelin inserts. I've never had the arm angle adjusted, and so far the chattering and other annoying noise is gone. They are smoother on a bone dry windshield than they used to be when it was misting out. Could be that mine weren't chattering as heavily as others
Old Dec 16, 2005 | 06:32 AM
KosherBenz's Avatar
Its big and Grey!
how much does the dealer get you for wiper blades?
Old Dec 16, 2005 | 11:02 AM
Flash Gordon's Avatar
2003 E500, 2004 G35X
I went to the dealer and told them about the problem and they replaced them free. one of the very few things the dealer has done right!
