Rear Brake Pads at 32k miles?
I can do brakes, so I said I'd take care of it, to which he then explains that I'd have to have the hard and software in order to do the job since its brake-by-wire. Nice.
So two things: One; Why rears pads low with 32k miles and the fronts are fine? Two; Is his statement true?
Fill me in...
Fill me in...
AND rotors at 20k miles. Now wouldn't that suck. It could always be worse. If you do the pads yourself, take the key out of the ignition. Unplug the SBC connector, replace pads, plug in connector (be careful to install it correctly). Before starting the car, pump up brake pedal to build pressure to take space between pads and rotors (if not, may cause a fault in system because it freaks out because of the extra effort it took to make contact-----talking from experience). Good luck.
There is absolutely NO physical link between the rear calipers and the brake pedal in this car. The rear calipers are totally 100% brake-by-wire.
When you take the key out of the ignition and disconnect the SBC module, make sure you DO NOT USE YOUR REMOTE TO UNLOCK THE DOORS OR OPEN ANY DOOR!!!! These things will also make the SBC run a test squeeze on the calipers.
Also, I think that you are doing quite well for getting this kind of mileage out of these pads. The rear pads are very small and they are tapered significantly. You must be easy on the brakes like I am. Yet, my rears are wearing a bit faster than the front so far. I still have over 80% of the pads left at 14,000 miles; we will see how it ends up though.
Steve
