E-Class (W211) 2003-2009
Why the "REST" button doesn't do anything?
Old Apr 11, 2006 | 08:02 PM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
Has anyone tried working the REST button on the HAVC? I was pressing it and holding it for several seconds and nothing. Since I asked becuase on my previous E320 W210 works, and it displays on the Climate control screen, showing you different things, such as Engine Temp/ Battery Voltage charge/ Speed and so forth. Why the W211 doesn't do anything? Am I missing something or is there a purpose there if it doesn't do a thing?
Old Apr 11, 2006 | 08:15 PM
macross811's Avatar
You must remove the key from the ignition then press the rest button.
The light on the buttom comes on and you hear the fans running as you leave the car.
Old Apr 11, 2006 | 08:49 PM
Brian_I.'s Avatar
w211 & w124
Yes, macros is right. It is for in between short trips to keep the car's climate more even by using the residual heat of the engine to run the HVAC.
Old Apr 12, 2006 | 11:04 AM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
In humid climates the a/c evaporator retains some moisture and mold will grow on the evaporator. The Rest feature can be used to dry the a/c evaporator.
Old Apr 12, 2006 | 11:49 AM
Brian_I.'s Avatar
w211 & w124
Very true, especially when you're experiencing issues with the HVAC having a funny smell at startup. Hitting REST when you park helps to eliminate that odor the next time you hop in your car.
Old Apr 12, 2006 | 02:16 PM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
A/C smell TSB
A good soul on this forum posted the latest TSB's, one of which describes, in detail, how MB is required to get rid of the musty smell( aka mold) in your A/C system.
Old Apr 12, 2006 | 06:09 PM
Double Eagle's Avatar
2003 E-500
I really like this feature in both hot and cold weather. If it's cold, you can hit it when you for a short time into a store and come back and find your car still warm. I've heard they have taken this away with newer models as part of their "decontenting".
Old Apr 12, 2006 | 07:07 PM
sl561's Avatar
2015 E350
BenzVinc's question was about getting read-outs after pressing the REST button, which I was also able to do in my former vehicle (MY 2000). That is, by pressing and holding the REST button (while the car is running), you could get a read out of the inside cabin temp, and presumably other things as well. My 2005 211 still has the REST button, and interestingly, I was just thinking about trying this the other day, but got side tracked and haven't done so yet. I'll try to remember on my way home tonight, to see if it does/doesn't work. This was a special function, in addition to it's primary function, which is to heat the car after the engine has been turned off.
Old Apr 12, 2006 | 11:32 PM
alewifebp's Avatar
2014 BMW 550i
The W211 does have this functionality, but it is not the REST button that does it. It is some other combo of buttons. As I recall, you can get tons of information about the car through this.
