E-Class (W211) 2003-2009
A/C unit loud?
Old May 2, 2006 | 08:25 AM
The Godfather's Avatar
4 wheeled car.
A/C unit loud?
In my 2003 E320 when the fan is on position 1 (lowest), I can hear a noticeable drone. When I turn it off the car is super quiet. Is that how you guys' A/C fan is or is it just mine? Car is under warranty still so I might as well get them to fix it.
Old May 2, 2006 | 11:53 AM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
If by "drone" you mean an electric motor sound, or mechanical sound, I don't hear that. All I hear when air is blowing out of the vents (at any speed) is the sound of the moving air itself.
Old May 2, 2006 | 11:56 AM
4 wheeled car.
Yeah there is a very noticeable droning noise that isn't the sound of air blowing out. It's definitely sounding like a motor humming. thank god for warranty!!!!
Old May 2, 2006 | 08:56 PM
Brian_I.'s Avatar
w211 & w124
Oh lord, not this clown...who said you could buy a w211? Nah, just messin' with you. The noise is common. Good luck getting a dealer to fix it though. Some folks on here have had it fixed and some have not, I'm in the latter group. I am currently working directly with MBUSA and DTLA Motors to fix it so I will let you know (especially since you're in LA too, I think).
Old May 4, 2006 | 11:15 PM
Le Burpor's Avatar
BMW E60 M5 - '08
I hope you don't have the 'whistling' noise issue when fan speed = 3 and at forward vents only setting. Quite annoying.
Old May 5, 2006 | 01:09 AM
4 wheeled car.
I just went to the dealer. He said "Well sure we can check it out, but it may be leaves that are stuck in the pollen filter, which is in the glovebox, so if that's the case, we gotta charge you it's not covered underwarranty and that'd be $140"
I told this nig, to just go and check it out and it surely doesn't sound like that's the case. *****. May 17th is my appt.
Old May 5, 2006 | 11:22 AM
Barry45RPM's Avatar
2015 ML 350
I dont have a drone, but on the lowest 2 speeds I hear a noise as if the squirrell cage blower is rubbing on paper or leaf debris. If I had to guess, I'd bet its rubbing on a little piece of insulation material thats out of place in there.
Old May 9, 2006 | 08:28 AM
Scambo's Avatar
'13 E550 W4
I have the loud drone as well. Seems to only appear when the blower is set higher than 3 bars. Its unfortunately loud at those settings. The sound I'm referring to is not air blowing through the vents, but rather a noise coming from the AC unit or blower motor in the engine compartment. Thoughts?
Old May 9, 2006 | 11:41 AM
Barry45RPM's Avatar
2015 ML 350
Its the radiator fan that is used to dissipate the extra heat when the inside A/C fans are on high or Max Cool. Its as loud as a single engine plane.
Old May 9, 2006 | 09:14 PM
Scambo's Avatar
'13 E550 W4
Should it be that loud normally, or is there a warranty fix from MB?
Old May 10, 2006 | 11:26 AM
Barry45RPM's Avatar
2015 ML 350
That's the normal operational noise it makes. Maybe that's why MBs are sound insulated so well?
Old May 10, 2006 | 11:07 PM
alewifebp's Avatar
2014 BMW 550i
What's funny is the sometimes scared look on pedestrians faces hearing what they think is you revving the car about to run them over.
Old May 11, 2006 | 10:42 AM
4 wheeled car.
no no that's not it. come on now, I'm onto my 10th+ Benz, I'm not a retard lol.
