E-Class (W211) 2003-2009
Command keyboard setting problem
Old May 28, 2006 | 07:54 AM
amf_bv's Avatar
Hi.
I have some weird problem . the right keyboard ( that with numbers ) is setted wrong in my car or I suppose this is the problem,
cause , when I type
1 - it goes to some other function
2- it goes to navi menu
3 - it types 9
4 - it mutes the system
and so on ....
everyone know what is the problem ?
If I press 3 , three times, it goes to the keyboard and model menu , where i choose w211 for model and keyboard then I hit BACK,, and nothing hgappens.
If I am in the phone menu, I press 7 it goes to 7 channel for FM...
and so on and on...
I dont know how to fix that .
Attached Thumbnails Command keyboard setting problem-hpim0011-2.jpg   Command keyboard setting problem-hpim0009-1.jpg
Old May 28, 2006 | 07:57 AM
amf_bv's Avatar
2
Old May 28, 2006 | 07:58 AM
amf_bv's Avatar
W211 E 270 CDI model 2003
i forgot to mention the car model .
Old May 30, 2006 | 08:16 AM
Miguk_Saram's Avatar
'07 GL450
It appears you have been playing with your keyboard and model settings (and changed it to something other than w211_xxx)...
Try to access the keyboard and model screen again. Once there choose the W211_ECE options for both, then power off the COMAND, lock your car and move away (more than 1 meter) for about 10 minutes (go have a beer, or something).
When you come back, the settings should have kept, and everything should work normally.
GL.
Old May 31, 2006 | 05:15 AM
amf_bv's Avatar
thank you.
thank you men. it worked after I have unpluged the power. anyway, your method is good also.
thank you very much..
please help me with something else.
i go into engineering mode, but the menu # * left arrow, doesnt work for my car.
do you happen to know other combinations ?
thank you and best regards,
cata
Old Jun 25, 2006 | 10:33 AM
splang's Avatar
me too!
I have tried that combo within Engineer menu to get to addition items.
I want to change my DVD region...
(uk spec late 2003 w211 e500)
Thanks in advance all
Steve
Old Jun 25, 2006 | 01:15 PM
splang's Avatar
sorry , my previous post wasn't clear.
Does anyone know the key combo to get into hidden section within engineer menu - so you can change dvd region??
