E-Class (W211) 2003-2009
Transmission flush/oil and filter change at MB dealer: Who's done it?
Old Jul 17, 2006 | 05:02 AM
Frank Wiesmann's Avatar
Since I am planning on keeping my car longer, I thought it might be good to have the transmission flushed and have the oil and filter changed. I figured the best place to do this would be the MB dealer since they are the most likely to have a machine to flush the transmission. Has anyone here had this done? If so, what were the costs and how satisfied were you with the results (smoother shifting, etc.)? Any input would be appreciated. Thanks!
Old Jul 17, 2006 | 08:22 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
I've have it done on all 3 of my Benz's, not at the $tealership though.It cost me $150.00 per car at my independent shop.
Old Jul 17, 2006 | 09:00 AM
SUNILP's Avatar
2015 E250D
try to find a shop using BG products for the tranny flush. www.bgprod.com
Old Jul 18, 2006 | 11:09 AM
BudC's Avatar
2011 E550, 2013 GLK
If you have an Indy do it, make sure they use the correct ATF fluid. Mercedes have changed the fluid they recommend for the 7G in the last year or so. I think it's called ATF 3353 (A0019894503). I also think they recommend FUCHS ATF 28 (A0019894603) for the 722.8 (5G?) transmission.
It appears that Mercedes are now recommending a one time (first time) change at 40,000 kilometers and then every 60,000 after that.
If you have an Indy do it, make sure they are properly equipped and know what they are doing.
