DIY Springs replacement?
I looked at the way the all the coil sit on my non-airmatic and it looks to be like any other cars except for the rear, much more like a truck using Shocks instead of struts.
The rear should be extremely easy I have not disassemble the front but it don't look hard either. I have access to a full body shop and spring compressors. I'm probably going to be doing this myself since I have DIY springs on my last 4 cars. Anyone would recommend against it? |
Careful with the SBC brakes.
Don't worry about the brakes, the job does not interfer with the brakes. Done it myself and no probs at all, you sound like a experienced diy so go for it. Save 300.00 on labor for other mods plus I know it's done right. Money can't buy piece of mind.
You may also throw out the alignment of the front end when you pull the struts out.
Regards, paul... |
yah allignment is already a must. I'm dropping in H&R 1.5 front and 1.3 in back, I hope they can do something about the camber. 19" tires are got damn too expensive to be replacing every 6 months.
Anyone that lowers a car should know to get a alignment after, but as for the camber I know carlab a sponser has k-mac camber correction kits. Hope thats helps.
I poked around Car labs and don't recall seeing front and rear, I believe they only have the fronts
Regards Darwin W Mercedes Tuning Specialist @ CarLAB MS |
Hey Darwin, I still need to have you guys check out the balancing on my tires. :) PM me with the price. on those camber kits.
Dannie, You never came that saturday :smash: , anyway call me at the shop so i can schedule you in :D. I'll have to find out the price on the K-MAC kits, There are some changes in prices since the last group buy. I'll PM you tomorrow. Regards Darwin W |
