E-Class (W211) 2003-2009
UGh, low beam light is out
Old Aug 22, 2006 | 12:40 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
It was fine today when I had them on, when I went in the store and back to the car. WHen i turned on the light my message came up said left low beam defective. I got out and my left headlight is out, I was in disgust. How hard to replace the bulb in terms of access to it?
Old Aug 22, 2006 | 01:26 AM
2001CLK's Avatar
2001 CLK320, 2003 E320
Depends on what side.. The passenger side is fairly easy but the driver side can be a bit tricky..
GOod LucK!
Old Aug 22, 2006 | 01:27 AM
AkMadness's Avatar
Mercedes E350, E550s on it's way!
Well, for me when I changed them on my E350, it wasnt that complicated, but depending on the postioning of your motor, SMALL hands are a necessary. Theres a cap you need remove by just turing, the houseing unit for the light is boom right there. The trick is getting the new light in, not really out.
Dont know if that helps you out at all but, in reality the task in relatively easy and about a 10 min job tops
Old Aug 22, 2006 | 01:35 AM
W211 Ryda's Avatar
2004 E320
very easy to change whether you have HID or halogen. if you have HID...see if your dealer could repair/replace it under warranty.
