E-Class (W211) 2003-2009
Replacing rotors DIY? e500
Old Aug 26, 2006 | 08:27 PM
OB_330CiC's Avatar
Like many folks on the forum my wifes 03' E500 had rotors and pads replaced at 22K miles, a record for any car I've own on two fronts: the MTBF (mean time before failure) and record price of $1K for the job.
But since we all love these engineering machines I figured I might as well get good at it since it looks like replacing these puppies very often is one of the side benefits of SBC. So DIY is the way to go from here on forward
I've searched the forum and found some very helpful info on a DIY for replacing the brake pads, but not much on the rotors.
Can anyone point me to a link or information on DIY for replacing the E500 rotors? Thanks in advance
Old Aug 28, 2006 | 08:58 AM
vettdvr's Avatar
03 E500 and Corvette
I haven't taken mine off yet, but what I see is that it is typical remove caliper and then rotor can be removed. Nothing exotic. I won't hesitate to pull mine when I need brakes again. 54K and F/R 's have been replaced at dealer. They didn't call just replaced them. Now they have a stop/call order on all service other than oil change. Jim
Old Aug 28, 2006 | 10:14 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Jim,
If you DIY, here's an idea of parts prices (taken from www.allgermanparts.com):
For 2003 E500 --
Front disc -- Zimmermann, $66
Rear Disc -- Zimmerman, single disc $42, vented disc $54 (sport pkg?)
Front pads -- Pagid $87, Jurid $79
Rear pads -- no brand listed, $75
Parking brake shoes, Textar, $40
Regards,
paul...
Old Aug 29, 2006 | 10:22 AM
vettdvr's Avatar
Thank you Paul I will certainly look into it.
My job this week wasn't the MB it was my Powerstroke diesel changing tanny fluid and repair of 4x4 locking system. Whew,, that 's out of the way for a while.
Jim
Old Aug 31, 2006 | 12:47 PM
CynCarvin32's Avatar
Mercedes Benz
List of items that makes the SBC pump seat the pads even whenthe key is not in the ignition.
1) Touch a door handle (with keyless go)
2) open a door
3) turn steering wheel -- if you have the car in the air you can trigger this by just working on the caliper.
4) have a person attempt to unlock a MB in the area that could make your car read a MB key in the vecinity.
The list goes on and on for about 4-5 more items but lets say you are working on the brake system and it goes to seat the pads. You will lose a finger. My tech was cool with just doing the brakes on the side for some cash and that is the best way to go about having a sbc car's brakes replaced.
My tech showed me his hand with a finger bent down and said unless you want to walk around like this I would not try to change the brakes on a W211 or R230 yourself. Hes not a guy trying to bill hours and instead hes a friend.
Old Aug 31, 2006 | 05:49 PM
jschade's Avatar
2018 S450, 2019 Range Rover LWB, 2015 Range Rover, 2019 S560 Cabriolet (awaiting delivery)
I thought this is why you are supposed to unplug the power harness for the SBC unit? Your tech friend should have shared that with you. Seems relevant. There are past post on exactly how to unplug SBC, including pictures as I recall. May want to check that info out.
