E-Class (W211) 2003-2009
Hey! You Guys With '07s ...
Old Jan 8, 2007 | 05:52 PM
Barry45RPM's Avatar
2015 ML 350
I had intermittant operation of keyless go operatin (It even stopped cranking mid crank & displayed "key not recognized"!)on my '04 for the 1st couple of years, 'till they swapped out the "Brake Switch". Try stepping on the brake pedal a little harder. If they doesn't work, have them check the "brake switch"... They replaced mine & the keyless worked every time after that.
I'd have thought they would have solved this by now.
Old Jan 9, 2007 | 01:11 AM
J Lucas's Avatar
keylesss go
LOL,
Thank god someone else posted that. I also had some intermittent issues with my keyless go. This is my first mbenz with the feature, the clk did not have it so i thought i was just releasing the brake pedal too quickly. When i firmly hold down the brake the 2nd time then push start it goes. Or maybe its just because its the second time?
Old Jan 9, 2007 | 11:15 AM
ddskier's Avatar
'10 E550 4Matic, '09 S600, '07 CL600
Originally Posted by Barry45RPM
I had intermittant operation of keyless go operatin (It even stopped cranking mid crank & displayed "key not recognized"!)on my '04 for a couple of years. Try stepping on the brake pedal a little harder. If they doesn't work, have them check the "brake switch"... They replaced mine & the keyless worked every time after that.
Interesting, I'll have to give that a shot.. Thank for the idea.
It really pisses me off in the E, because my S and CL don't have this issue.
Old Jan 10, 2007 | 03:42 PM
BlueMonk's Avatar
Interesting, I came to this thread because I am getting frustrated with my 04 E320's 'flaky' keyless go and thinking about a new E. Disturbing to see that it can still be an issue four years later. Still I will drift over to the new car section when I drop mine off for them to 'fix' my key problems.
Old Jan 10, 2007 | 06:29 PM
Acrobat's Avatar
I couldn't be happier. My old CLK430 was wearing out, and i needed a new ride. The E350 fills the bill nicely.
BTW, I'm Tony, and I'm new here. I can't wait to begin contributing to this great forum!
Old Jan 10, 2007 | 06:35 PM
Acrobat's Avatar
Originally Posted by A C
Ditto - I had an E430 and the only difference is you don't hear the V8 grunt. The V6 is very quick if pushed.
Agreed. I nearly pulled the trigger on the E550 but because of the peppy V6 I went for a similarly equipped E350. I used the nine grand I saved as a down payment on a new Harley!
