MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W211) (https://mbworld.org/forums/e-class-w211-20/)
-   -   What's this button do? (https://mbworld.org/forums/e-class-w211/178315-whats-button-do.html)
Benz-O-Rama Jan 18, 2007 01:27 PM
1 Attachment(s)
Ok, so I've never been in the backseat of my car until this last weekend. The car nookie takes place in the SUV :naughty:
Anyway, on the rear dome light there are 4 buttons. 1 on each side and 2 in the middle. The 2 on the outside are reading lights for the rear occupants. What on Earth do the two in middle do? From the picture on them, they look like some sort of dimming buttons? Mine do absolutely nothing no matter what combination of lights are on. Headlights on, headlights off, map lights on, map lights off, dome lights on, dome lights off....nothing. Look at this pic:
Attachment 96174
SAguirre Jan 18, 2007 01:43 PM
Attachment 96174
They dim and brighten the ambient lighting when the inside ambient lighting is on. So if the interior light setting is set too high the people in the back seat can override it, but only on that overhead light fixture.
Steve
konigstiger Jan 18, 2007 01:48 PM
Correct. If working properly, solid should make the ambient light bright, the other dimmer.
KosherBenz Jan 18, 2007 01:53 PM
its the eject button. DO NOT PRESS IT!
Benz-O-Rama Jan 18, 2007 01:56 PM
Interesting, maybe mine are broken.
With all interior lights off and just the ambient lights on, these buttons still do nothing for me. I do have my ambient set to '5' on the MFD though. So I would think at least the dimming one should do something, right?
I'll check again tonight just to make sure I haven't been smoking too much crack but I'm pretty sure they did nothing.
Then again, can you really smoke TOO MUCH crack? :smokin:
HA! I thought for sure that would be the first response!
TREZ63 Jan 18, 2007 02:04 PM
Yours work just fine, the button increases and decreases in VERY VERY small increments so keep your finger on it and you'll see a difference.
This is also controlled by the comand setting in your cluster.
Barry45RPM Jan 18, 2007 02:09 PM
You have to pres and hold. It takes a couple of ticks of the second hand before they start to work. Think of the symbols as "Ramp up" & "Ramp down".
starbrite Jan 18, 2007 02:53 PM
I wondered about those buttons on my car when I bought it, because there was absolutley
NO mention of that dome fixture buttons in the owner's manual.
AsianML Jan 18, 2007 03:05 PM
Makes it brighter where the sun don't shine. The little painted symbols explain it all.
lordnkv Jan 18, 2007 05:30 PM
I have been having a problem with these buttons. They work fine in controlling the brightness of the rear ambient lighting. However, I cannot get the cluster control to change the rear lighting. So the front ambient lights work with the cluster control and the rear work with the rear buttons. But I think before the cluster control would change both sets of lights. Any ideas on how to fix it?
Barry45RPM Jan 18, 2007 05:59 PM
It ain't broke. Thats how it works.
Benz-O-Rama Jan 18, 2007 08:12 PM
OK.
2 things:
1. I love the crack pipe. And yes, I held the little dimmer button and sure enough, it dimmed. When I was trying it before, I was tapping it. Holding it does the trick.
2. My cluster control (MFD) controls both the front and rear when I change my ambient light setting. They change together.
Thanks guys
Cops_h8_me! Jan 18, 2007 08:16 PM
crack kills! :topic:
netwalla Sep 17, 2010 11:34 AM
Ambient Light
I have tried my rear ambient light it does not come up at all,
Any clues,
I have a panoramic sunroof with the rear ambient lights,
The front work no problem its the rear ones
Please help
charliele729 Sep 25, 2010 10:44 PM
If I remember correctly, the rear seats dont have ambient lighting (the circle ring like the front does). Is the front and back suppose to light up as ambient lighting, or is it only for reading lights.
Miguk_Saram Sep 27, 2010 07:10 AM
charliele729:
Yes, the rear seats do have the ambient ring and an adjustable setting.
netwalla:
Turn the ambient setting on the MFD all the way up to 5, then press and hold the rear illumination button until the lights are at their brightest.
Once you confirm its operation, adjust the settings to your liking.
GL.
hyperion667 Sep 27, 2010 08:33 AM
rocket launchers??
charliele729 Sep 30, 2010 04:41 PM
Ok, I have confirm that my 09" does not have that option. There is no circle ring light, just two reading light. I guess that change it from the previous models.
rhurtado Oct 23, 2010 12:18 PM
I was just getting ready to go out to my car with my phone to take pics but now I see I'm not the only one. I was doing the same thing pressing those buttons and nothing was happening. I thought something was broke. I also noticed that there was ABSOLUTELY no mention of these buttons and their function in the manual. I will try holding the button down to see what happens. I can just see my neighbors wondering what the hell I'm doing sitting in my own back seat, alone in the dark, with the car running....:crazy:
© 2026 MH Sub I, LLC dba Internet Brands
