When to get first tire balance on 07 350
2007 E350 Sport Alabaster White P1 Package
I've got 6,000 miles on 07 E350 Sport and I was wondering is now a good time to balance the tires? I'm not feeling any type of vibration or anything but I like to stay on top of it so that I won't down the road. I have Michelins on the car. Should I balance them now or wait a while longer? My concern is that the dealer might screw up my existing factory balance.
2015 ML 350
2007 E550
Maybe this is a belief left over from the olden days, but I learned that reversing the direction of rotation of a tire after it's been run a while screws with the wear pattern on the tread lugs and ain't so good for the cord. Rotating only front to back is still recommended by a number of auto info sites (incl. Edmunds), and I abide by it, but do people here still believe it's necessary to avoid side to side? Re: balancing. I wouldn't mess with it unless something's wiggling. Otherwise you're just asking for trouble--scratched rims, marred lug nuts, and possible a vibe where there was none before....
Harley-Davidson
Originally Posted by Forumid
Maybe this is a belief left over from the olden days, but I learned that reversing the direction of rotation of a tire after it's been run a while screws with the wear pattern on the tread lugs and ain't so good for the cord. . .
Harley-Davidson
To add to the above post, here is a link to the Tire Rack with their advice on tire rotation. http://www.tirerack.com/tires/tirete...¤tpage=2
Adding to the confusion, my M-B owners manual says NOT to reverse the rotational direction of the tires. I am going to follow the Tire Rack's advice to rotate side to side.
09 c63 10 c300 Nissan truck
rotation
I've switched tires side to side several times on MB's before and never had any problems. I agree with cyclerider that it helps smooth out any cupping that occurs. If, however, your tires have a tread pattern that is not assymetrical [i.e. directional] then you have no choice but to live with loud tires or buy new ones long before the tread is gone
LS7 powered Corvette
Haha, funny how something so simple can go so wrong sometimes.
FYI, I used to rotate/balance the tires on my 06 350 about every 3k miles. I would usually notice a slight shimmy/vibration at highway speeds. When I balanced them, I might have one or two wheels come up 10-15 grams off. The car was lowered, and I attribute most of that to not having proper camber in the front end.
The car had 18k miles on it when I got rid of it, and had around 4-4.5mm tread depth all the way around on the factory MXM4 Michelins.
