Opening/Closing windows with key
The feature of opening and closing the windows with my key is not working.
I recently had the battery disconnected to install the Sirius radio module. Could this be the reason and how would I restore this feature. I have already synchronised the windows. Thanks 2003 E500 |
Synchronised Windows??
Originally Posted by Piranajoe
(Post 2290737)
It could very well have caused your problem. I don't know how to fix it other than asking your dealer service rep. I had to resynchronize my pano roof once when they forgot to do it after they had disconnected the battery (I think--lol). It was simple to do. They told me over the phone how to do it.
You may have a problem with the IR sensor in the door handle. Try it with the key directly over the sensor, and do it on both the driver and passenger side. It's not related to disconnecting the battery...
There is no IR sensor on the passenger door handle, only on the drivers side. It failed on my '04 too & would only worn intermittantly.
Im sure you know how to operate the controls, so it might be something in the programming of the ECU...I would take it back to the dealer and have the run it on their computer to see if there are any codes popping up that you are not aware of...
(Post 2290737)
I recently had the battery disconnected to install the Sirius radio module. Could this be the reason and how would I restore this feature. I have already synchronised the windows. Thanks 2003 E500 Make sure IR sensor is clean (driver door handle). Check the key battery: Press unlock, or lock button and the LED should light up briefly. Restore factory setting: Press unlock and lock button simultaneously for couple of seconds until LED flashes twice. BTW you can switch between opening only driver’s door/fuel cap, or all doors/fuel cap. If need be IR sensor I think it is part # A203 760 23 77 (door tumbler). Aside, has version coding of the MOST ring been performed by the dealer and SIRIUS been activated? |
(Post 2292499)
It could be coincidental that the IR sensor started malfunctioning, probably not related but I would revisit all connections anyway for precaution. Also for precaution:
Make sure IR sensor is clean (driver door handle). Check the key battery: Press unlock, or lock button and the LED should light up briefly. Restore factory setting: Press unlock and lock button simultaneously for couple of seconds until LED flashes twice. BTW you can switch between opening only driver’s door/fuel cap, or all doors/fuel cap. If need be IR sensor I think it is part # A203 760 23 77 (door tumbler). Aside, has version coding of the MOST ring been performed by the dealer and SIRIUS been activated? I installed the Sirius myself and it was basically plug and play. When I reconnected the battery the Sirius radio came on without any recoding. |
(Post 2292659)
I tried the passsanger door and all the windows do open/close. I cleaned the Ir on the driver side but still no luck. I installed the Sirius myself and it was basically plug and play. When I reconnected the battery the Sirius radio came on without any recoding.
Originally Posted by Barry45RPM
(Post 2291647)
(Post 2292944)
Have you tried both keys on both the driver and passenger sides? Reason I mention this is that sometimes one key will work consistently and the other will work intermittently. Csumt76 called it, looks like the sensor needs to be replaced.
Thanks |
common problem. Needs a new IR sensor
(Post 2294851)
I think its the sensor, the passanger side works with both keys.
Thanks |
You can rule out the 2006 E350 with having Passenger side IR sensors. I know the w210 has passenger side ir.
(Post 2295469)
How are you able to lower the windows on the passenger side with the key? There's no IR Sensor on the passenger's outside handle.
2003 E500 Both Sides have IR
In my case, neither key/door works. I tried resetting one key via the above procedure, but that did not help. It must be that both door's IR sensors had gone bad.
Originally Posted by Gethen
(Post 3002940)
How do you sync the windows?
key workst perfecly whit doors, but i cant open/lock windows :nix: |
Originally Posted by SergioM
(Post 3003841)
key workst perfecly whit doors, but i cant open/lock windows :nix: So how was it with one touch closure? Did it work? Your user manual explains how to normalise the widows, basically press the close button until windows close and keep the button pressed a few seconds after the window is closed. How did you try to open/close the windows with the key, did you point the door and keep the open/close button pressed? |
