Mercedes-Benz Giveth .. and Mercedes-Benz Taketh Away!
Probably just a few little tiny Add-ons, or improvements.
BUT, I never expected a “taketh away!”
For 08, no more turn down right mirror when you go into
reverse! Shop said they dropped that for the 08‘s. I liked
that a lot. (I wonder - what Other “taketh” have I not yet
discovered?)
jimm
‘08 E350 Sport, P2, Black/black,Parktronic,
Voice, Bluetooth, Burl Walnut, Split rear seat,
Wood/leather steering wheel
There has been a few comments around this forum that the mirror is still capable of tilting all the way down, it was just turned off within the Mercs software.
Apparently they can turn it back on via the STAR program.
Rarely do I need it to look down, If I do, I use the button to adjust it down & when I finish parking I press Driver # 1. No, its not automatic, but it beats the hell out of not having the mirror go back to the full upright position, and as I said, I personally hardly need it to gow down. Being an MB owner I am relegated to parking far far away from anything else resembling another car or a store.
The sales literature for the '07s said that depending on the date of production, the car may or may not have the parking aid feature. My '07 was built Jan 21, 07 and doesn't have it.
discovered?)
jimm
The MBUSA 211 never had this feature however in Europe it is standard. You can install them or have them installed for you one source being: https://mbworld.org/forums/members/1384-mbenznl.html
discovered?)
jimm
Your 08 E350 is pretty much exactly what I am going to lease, but I am planning Iridium silver/black, am skipping the split rear seat, and will probably pass on the Sport package. A couple questions:
Did you get the Sport for appearances or because the drive is different? Also, have you found the P2 package to be worthwhile? Finally, how does the voice work. Does it respond at any time or do you activate it with a button? Thanks
What the voice is designed to operate, it does so flawlessly. P2 will give you Bi Xenon headlights. Quite simply the best headlight system you will ever drive with. If you can "swing it" do it! I day to day driving, the Sports Pkg, doesn't give you more of a sports car. If they charged even a Grand for it, I would have skipped it... but I wanted the LED tail lights because of THEIR look & visible Dual Exhaust is nice to look at. (They're ALL dual exhaust anyway.) For me it just made the car a little more of a stand-out to people who know Benzes. (I hear ALL 550's are Sports for '08, so on a 350, it will stand out even more.) The staggered wheel set up is nonsense to me because you lose the ability to rotate the tires, so tire life is an issue. Also the extra wide rears are noisier as they "slap" across seams in the cement pavement at lower speeds. The Sports Pkg wheels however are much nicer to look at than the everyday standard wheels. There is virtually no difference in handling between Sport & Non Sport, as I've had both. The Blue Glass? So what? It doesn't do anything & might look "off" with some paint colors.
