E-Class (W211) 2003-2009
SPACERS - bad experiences
Old Jul 27, 2007 | 11:26 PM
Royale's Avatar
Considering installing spacers.
Any bad experiences to stop me from doing so ?? Pls. share.
Thanks.
Old Jul 27, 2007 | 11:32 PM
E55texas's Avatar
04 e55
Wheel spacers?
Bad idea, I was driving a friends truck with spacers, the left front wheel fell of on a turn. We put the wheel back on, He drove the truck and 4 miles later the left rea fell off on a turn
Old Jul 28, 2007 | 01:17 AM
white07w211's Avatar
2007 e350 4matic
what ever you do stay away from spacers. I had spacers on my maxima and was driving on the highway the wheel flew of it was next to me coasting while i was trying to pull off.
Old Jul 28, 2007 | 02:00 AM
raymond g-'s Avatar
99 E320
spacers are unlikely the cause of wheel coming off. sounds more like
someone got lazy and didn't purchase a longer lug bolt (MB) or did not take
into consideration the short lugs on for non MB wheels. notwithstanding the
misplaced fear mongering, use of spacers is usually a cheap *** cure for poor
wheel purchases - like shoving tissue in a bra, or socks in your shorts.
better to have purchased wheel with the proper offset.
Old Jul 28, 2007 | 04:02 AM
W Cole's Avatar
makes your daughter horny
On the E class the front hub is very long, you can easily run a 10mm or larger non "hubcentric" type spacer (this is what I have) with PLENTY of hub left over for the rim to mount onto. However, you must be VERY CAREFUL when tightening the lugs. You must tighten them while the car is in the air, and use 3-4 incrementally increasing torque settings in a star pattern.
If someones wheels are falling off it means they are using an incorrect bolt length, incorrect torque specs, or a spacer that is too thick (I wouldnt go over 25mm).
