E-Class (W211) 2003-2009
Ignition to start the engine problem
Old Sep 4, 2007 | 06:51 PM
Tariq's Avatar
S500 W223 2021
Hi,, I have 2003 E500 , and whenever I need to start the engine, some time the ignition take time to turn on the engine, i just hear the sound of the ignition for 7 seconds may be without turning on the engine then I remove the key and restart the ignition then the engine work , however a logo of engine appear in the display, any body know what is this problem from?
Old Sep 5, 2007 | 04:31 PM
konigstiger's Avatar
'71 Pinto
Normally this would signal problems with the fuel injection system, exhaust system, or the ignition system. In addition the starter fuse in the driver signal acquisition and actuation module (SAM) might be malfunctioning whereas the currently installed 15 Amp fuse is replaced with a 20 Amp fuse - Fuse20A (part # N072581000306). Have a dealer or independent shop check it.
Old Sep 6, 2009 | 07:26 PM
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
Today my E started doing the same thing. I turned the car off at a store, went in for a few minutes; when I came out the starter cranked real fast about 10 times but the engine wouldn't start.
It has since returned to normal.
I read another post the says the Crankshaft Position Sensor could be bad.
What should I do????????
Old Sep 8, 2009 | 03:41 PM
mobinakhtar's Avatar
MY2004 E320
CLASSIC SYMPTOMS OF CRANKSHAFT POSITIONING SENSOR. Just replaced mine was doing exactly the same. Cold start was fine - when warmed up or short drives, it would crank and crank before starting. Next stage is that it will shut off the car at idle on traffic lights. Part is liek$35-$60 online. one 8E bolt and 15 mins of time (it is externally mounted. Search for "CPS"
Old Sep 10, 2009 | 01:18 PM
djmallya's Avatar
Thanks Moby!
This was starting to freak me out. I'll get right on it and let you know.
