E-Class (W211) 2003-2009
Survey: Navigation Routing Problem
Old 10-07-2007, 03:23 PM
Mavrogenis's Avatar
2018 E300 Luxury fully loaded
If you have a 2007.1 Navigation DVD and the system does NOT use a direct route to your destination please send me a PM with your experience. Two other members of the 211 forum and I have this problem. If others are also experiencing the same problem I will have more clout with MBUSA to have them investigate & fix this problem. I suspect the problem is either the 2007.1 version DVD coding or MB has not updated the COMAND software to work with this version that was released in July 07.
Thanks,
James
Old 10-07-2007, 06:10 PM
yikes's Avatar
06 e350 17 glc300
ive had 2005.3, 2006.1 and 2006.2...they all do the same thing in certain areas where i live which is incorrect. for whatever reason it wants me to make a left turn when if i simply go straight its more direct.
Old 10-07-2007, 07:18 PM
Artful Dodger's Avatar
2008 E320 Bluetec
Mine seems to be working fine. I assume my '08 has the latest COMAND software, though.
Old 10-07-2007, 07:54 PM
Mavrogenis's Avatar
Artful Dodger,
I would bet that you have NAV DVD Version 2006.2. Earlier 08 Models that I've checked have this version and it works correctly. But, when I put my 2007.1 DVD into an 08 system it screws up & will NOT plot a direct route!
Please pull your DVD out, check the version & let us know. The version # is printed on the DVD on the right side when held so you can read the label.
James
Old 10-07-2007, 08:03 PM
baxterdown's Avatar
1972 280SE 4.5
Sent you a PM.
Jose
Old 10-16-2007, 03:03 PM
Mavrogenis's Avatar
Navigation Routing Issue Solved
Actually solution is in work. Learned this from my SA today, 16Oct07, after his discussions with MBUSA. (Smothers European in Santa Rosa CA is a GREAT dealership). If you have a W211 including the 08 MY AND the Navigation DVD is version 2007.1 you have this problem.
The navigation system will not select the most direct route to a destination if carpool lanes are part of the direct route. It insists on routing you around sections of the highway that include carpool lanes.
MBUSA is aware of the navigation routing problem & is working on a solution. The issue occurs because of the way carpool lanes are coded on the DVD. The repair will be either an upgrade to the COMAND unit software or an updated DVD.
BTW, The 2006.2 version DVD does not have this problem.
Old 10-16-2007, 03:28 PM
jmorgis's Avatar
2013 SLK
So everyone should avoid 2007.1 and wait for 2007.2? Correct?
But what about the people who already are running 2007.1 they cannot go back to 2006.2?
John
Old 10-16-2007, 03:38 PM
Mavrogenis's Avatar
I would wait for the fix or see if the dealer can find a 2006.2 DVD which does not exhibit this problem. Early build MY08 E's, before July07, were delivered with the 2006.2 DVD.
I suspect if the fix involves updates to the COMAND software it might happen sooner than if it involves a new version of the DVD.
James
Old 10-16-2007, 03:43 PM
jmorgis's Avatar
2013 SLK
My understanding once your put in a newer version ie from 2006.2 -> 2007.1 you cannot go back...
John
Old 10-16-2007, 03:56 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
Originally Posted by Mavrogenis
The navigation system will not select the most direct route to a destination if carpool lanes are part of the direct route. It insists on routing you around sections of the highway that include carpool lanes. BTW, The 2006.2 version DVD does not have this problem.
Might I suggest whoever is experiencing this problem contact NAVTEQ to expedite?
http://mapreporter.navteq.com/dur-we...ER&language=en
Old 10-16-2007, 04:30 PM
V DuBb's Avatar
Mercedes Benz E350 Sport
my navi makes me go make a u - turn and keep fallowing that first route even if its faster/closer to go straight......
Old 10-16-2007, 04:41 PM
AndrewAZ's Avatar
BMW FTW
Just about everyone with a Nav system will have this issue.. Thats why MB says that not all roads and routes are up to date.
Old 10-16-2007, 05:26 PM
Dema's Avatar
i535
I have a similar problems with even older versions of CD/DVD. I tried to contact MBUSA without a success. MB isn't vendor of the system.
Old 10-16-2007, 05:29 PM
yikes's Avatar
06 e350 17 glc300
is it possible to downgrade disk versions...ie..go from 2007.1 to 2006.2?
ive heard once you upgraded to a newer version, you cannot go back
Old 10-16-2007, 06:32 PM
Mavrogenis's Avatar
Yikes,
Yes you can use the 2006.2 version DVD even if you have had the latest COMAND software update installed. That's the one that gives you ETA on the COMAND screen when the 2007.1 DVD is used. I know it works because I have done it. I borrowed a 2006.2 DVD and my routing issue was fixed but I lost ETA. And, I have the absolute latest, Oct07, version of the COMAND software
James
BTW. MBUSA is aware of the routing problem that the 2007.1 DVD causes & is working on a fix. More info here:
https://mbworld.org/forums/showthread.php?t=213055
Old 10-16-2007, 06:49 PM
yikes's Avatar
06 e350 17 glc300
Yikes,
James
i have the latest command sw...but i always thought once you upgraded to a newer nav dvd version you cannot go backwards...
btw i use 2006.2 and the latest command sw and still have the eta
Old 10-16-2007, 09:07 PM
tashakes's Avatar
2007 A8L 4.2
I have the 2007.1, yesterday I went to an admissions meeting with my son at USC (from San Diego), and the nav sent me on the 405 to the 110. I immadiately though that the problem I had seen here before was happening, as I was ready to go on the 5 to the 10. Turns out the nav was right, I made it there in less than 2 hours, and used the carpool lanes that are available about 90% of the way starting around Capistrano. I know the 5 does not have carpool lanes north of Irvine, so by following the rationale above, it probably saved me a ton of time. Maybe what they should do is offer carpool lanes as an option, now I am just not sure not to trust it completely anymore......
Old 10-16-2007, 10:24 PM
pinebaron's Avatar
07 E320 Bluetec
My car has 2006.2; it was delivered on 6/29/07 and I have had no issues with it.
Old 10-17-2007, 11:26 AM
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
I have 2007.1 in a 2008 E550 and also in a 2004 E320, both with the latest Comand update as well. I drive from time to time on the Long Island Expressway, which has HOV lanes, and the system does not reroute me. There are specific instances of choosing a route (not on a carpool route) that is more circuitous than necessary (one was fixed in 2007.1) but nothing like the more general problem described above.
Old 10-17-2007, 04:27 PM
hussainrafiq's Avatar
2004 Mercedes Benz E500
Thanks,
James
I have a Nav version 2006.2 in my 04 E500 and still can't get the ETA. Does anyone have the update from MBUSA for this fix. Keep in mind that I have a older version of the COMAND system.
Old 10-17-2007, 05:13 PM
'71 Pinto
Have your dealer update the COMAND software. Mention DTB P-B-82.60/382b and service disc W211589142200 will update the COMAND head unit software to enable: ETA for distance and time in status line, mute the navigation voice with quick MUTE press, and telephone signal-strength meter in status line during active Route Guidance. In addition, this DTB will update the Audio Gateway software as well if need be.
FYI: Current Navigation DVD 2007.1 (MBUSA part BQ6460229)
Old 10-17-2007, 06:27 PM
2008 E320 Bluetec
Artful Dodger,
James
Nope, I have the 2007.1 disk. Managed to plot some pretty intricate routes in the middle of Richmond, VA last week, too.
Old 10-17-2007, 08:54 PM
tashakes's Avatar
2007 A8L 4.2
Konig: Will this update lock the engineering menu on the Euro COMAND?
Old 10-17-2007, 09:11 PM
sack5000's Avatar
2015 AMG C63 S
Check and see if you have "avoid freeways" checked. That will foul the hell out of your routes......
Old 10-17-2007, 09:36 PM
'71 Pinto
https://mbworld.org/forums/showpost....7&postcount=11
Quick Reply: Survey: Navigation Routing Problem
