2003 E320 Fuel Filter
I have learned that the fuel filter is to be found in the fuel tank under the back seat. Easy for me to access because I have folding rear seats.
I have found a number of websites that sell fuel filters, but they look nothing like the photos that I have seen for the pump/filter assembly. Do I really have to replace the fuel pump or is the filter simply attached to it? please tell me it's a simple fuel filter....please! |
Originally Posted by mdreef
(Post 2517974)
I have found a number of websites that sell fuel filters, but they look nothing like the photos that I have seen for the pump/filter assembly. Do I really have to replace the fuel pump or is the filter simply attached to it? please tell me it's a simple fuel filter....please! As far as I know fuel filters are located under the car and you should not have access to it from the inside. I think it would be crazy to have anything that has to do with fuel in an area accessible from the inside. |
Originally Posted by guanabara
(Post 2520224)
I think it would be crazy to have anything that has to do with fuel in an area accessible from the inside. Looks like the filter is not a separate OEM spare part. http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=01 |
(Post 2517974)
I have found a number of websites that sell fuel filters, but they look nothing like the photos that I have seen for the pump/filter assembly. Do I really have to replace the fuel pump or is the filter simply attached to it? please tell me it's a simple fuel filter....please! There is apparently a different model for the 4-Matic cars. So make sure you get look up the right one. As far as location goes, try looking under the tank (forward side) under right side rear sear area. my cars are 99 so not sure why yours would be different as the E320 uses the same filter from 99 to 2003 on the E320 model. The car should be lifted at a mechanic shop for safety access from under neath. There are pressure clamps holding the hoses in place. The filter body is also held in place using a clamp. There is a plastic cover should be removed for easy work, |
Thanks Guanabara. Could you please give me the link that you mentioned?
The 03-E320 is the new body stule, so I believe that it would be different from 99 - but I'm not 100% sure.. Also, when I called the parts department dealer to ask for the fuel filter they said that it's part of the pump... MD
(Post 2520688)
Look at the link below, where you can see how the filter looks like.
(Post 2520740)
The 03-E320 is the new body stule, so I believe that it would be different from 99 - but I'm not 100% sure.. Also, when I called the parts department dealer to ask for the fuel filter they said that it's part of the pump... MD I am preparring to do this job on my car (haven't done one yet myself). I understand that there 2 hoses on each side of the filter. I believe (to be confirmed) that they need to be compressed enough to block fuel leakage. Then the clamps holding the hoses in place need to be removed. I read somewhere that those clamps sometimes break or can only be used once, so better get a set of 4 just in case. The filter body is also held in place by a clamp that needs to be loosened so that the filter can be taken out. I a still doing some research on this, so we are on similar paths. Soemtims it helps looking up the part(s) online so that it may be easier locating it on the car. Here is some information I was able to quickly find online: Makes > 2003 Mercedes > E320 > Fuel & Air System > Fuel Filter Part Number Brand / Description / Restrictions List Core Your Price Qty Select 0024773001 http://www.autohausaz.com/secure/Par...0024773001.jpg Knecht Fuel Filter; With 4 Push-On Fittings; 75mm Diameter Please verify appearance and connections on existing unit prior to ordering. 1 per car. $118.00 $37.95 71058 http://www.autohausaz.com/secure/PartImages/71058.jpg Bosch (Alternate Brand) Fuel Filter; With 4 Push-On Fittings; 75mm Diameter 1 per |
Thanks! I think I might have to look inside the tank to see what's there...I will also look underneath the car to see if I find what you have mentioned...
Thanks again!! |
1 Attachment(s)
I found this..... somewhere.....:rolleyes:
Thanks tashakes. From the pdf file that you posted...
"The fuel filter (55/1) forms a unit with the fuel pressure regulator, the left tank half fuel level sensor (B4/1) and the line package (6). The fuel filter (55/1) cannot be replaced separately." |
Originally Posted by X72
(Post 2523208)
"The fuel filter (55/1) forms a unit with the fuel pressure regulator, the left tank half fuel level sensor (B4/1) and the line package (6). The fuel filter (55/1) cannot be replaced separately." I went thru this ordeal about 2 years ago when I replaced my fuel filter. The filter is on the driver's side of the tank (and has a level float attached) and it has some tubes and a power harness that feeds thru a channel in the tank to the other side (passenger side) to connect up to the fuel pump. The fuel pump also has a level float attached. The job took me about 2.5 hrs to complete -- it's not difficult but a real PITA!!! The filter was about $100 and I purchased it thru one of the suppliers who discounts to MBWorld members. Regards, paul... |
Originally Posted by paulv
(Post 2523223)
X72,
1 Attachment(s)
Originally Posted by Diesel Benz
(Post 2523504)
I don't have this as the fuel filter on a diesel is at the engine bay but for my interest, can you clarify if you still changed the filter only while it does not appear to be a spare part from MB? An independent source would supply the filter part only and the pump assembly can be torn down and rebuilt with a new filter? Or was the filter part you mention an equal complete pump assembly as the spare part from MB?
This was the part number for the filter assembly: 2114704094. I also need these two parts since the filter part was the new replacement (I guess MB was trying to make this a common part): Harness 2114400507 : this was to connect up the fuel guage wiring to the new filter. bracket 2114700241 : this was to allow for the wider diameter fuel lines from the new filter to the pump -- this bracket snapped on the rim of the fuel pump. BTW, I bought these parts (and many others) from Rob Lewis who's a parts guy at Westchester MB in OH. He has an account for MBWorld members and I was happy with his prices/service. You can reach him 1-513-870-1030. I don't have any info on international sales from Rob. Hoped this helped. Regards, paul... added full procedure. |
Fuel Filter E320 2003
(Post 2517974)
I have found a number of websites that sell fuel filters, but they look nothing like the photos that I have seen for the pump/filter assembly. Do I really have to replace the fuel pump or is the filter simply attached to it? please tell me it's a simple fuel filter....please! Fredush |
Fuel Filter E 320 2003
May i ask what "TASHAKES" is/
(Post 2523553)
Unfortunately, tashakes only provided the first half of the procedure as the other half is for replacing the fuel pump but is needed to to the full filter replacement on a W211 gas car as it shows how the filter gas line connects to the pump.
Originally Posted by fredush
(Post 2694932)
Regards, paul... |
(Post 2523223)
X72,
I went thru this ordeal about 2 years ago when I replaced my fuel filter. The filter is on the driver's side of the tank (and has a level float attached) and it has some tubes and a power harness that feeds thru a channel in the tank to the other side (passenger side) to connect up to the fuel pump. The fuel pump also has a level float attached. The job took me about 2.5 hrs to complete -- it's not difficult but a real PITA!!! The filter was about $100 and I purchased it thru one of the suppliers who discounts to MBWorld members. Regards, paul... Fred |
(Post 2517974)
I have found a number of websites that sell fuel filters, but they look nothing like the photos that I have seen for the pump/filter assembly. Do I really have to replace the fuel pump or is the filter simply attached to it? please tell me it's a simple fuel filter....please! LETTER SENT TO MB USA JAN.23'09 MEMBERS SHOULD SEND MORE OF THESE LETTERS,THIS IS A RIDICULOUS ARRANGEMENT i own a 2003 e class (w211) with 60000 miles,the owner's manual suggests a fuel filter change at 60000.To my surprise and dismay I find that the filter is located INSIDE the fuel tank and it comes as part of the fuel supply pump and not as a separate part,needless to say the cost is enormous ...not to speak of the labour.I have since found out from other owners that after the change (performed by MB dealers) a number of them have had issues with the fuel gauge and low fuel sensor.A trusted MB dealer's service mgr told me that they have stopped changing these filters and have had o fuel problems with vehicules over 100000 miles.Please tell me the reason for the placement of the filter and the reason it is so expensive,have you since reviewed the advice to change the filter alltogether.Where is the fuel filter located in the W212?I also own a CLK cabrio 2004,is this a similar situation?Thank you in advance for your response. |
It is only a similar problem if the CLK is a v8.....
(Post 2705071)
May I ask where you bought the fuel filter for the 2003 E320,the MB dealer wants $241 for the part...
Fred
(Post 3294484)
W211 FUEL FILTER
LETTER SENT TO MB USA JAN.23'09 MEMBERS SHOULD SEND MORE OF THESE LETTERS,THIS IS A RIDICULOUS ARRANGEMENT i own a 2003 e class (w211) with 60000 miles,the owner's manual suggests a fuel filter change at 60000.To my surprise and dismay I find that the filter is located INSIDE the fuel tank and it comes as part of the fuel supply pump and not as a separate part,needless to say the cost is enormous ...not to speak of the labour.I have since found out from other owners that after the change (performed by MB dealers) a number of them have had issues with the fuel gauge and low fuel sensor.A trusted MB dealer's service mgr told me that they have stopped changing these filters and have had o fuel problems with vehicules over 100000 miles.Please tell me the reason for the placement of the filter and the reason it is so expensive,have you since reviewed the advice to change the filter alltogether.Where is the fuel filter located in the W212?I also own a CLK cabrio 2004,is this a similar situation?Thank you in advance for your response. I made a huge mistake, however, and I "neanderthaled" the plastic connection between the filter unit (on driver side) and fuel pump (on passenger side), so it broke! I just couldn't find the clip that would allow the barbed connection to release - VERY IMPORTANT! I admit that I am sometimes a neanderthal. So, my "do it yourself" project to save a couple of bucks ended up costing me over $600.00 because I had to buy a new pump as well...It also took much longer. I'm still ashamed of myself for making such a foolish mistake. Remember not to EVER force any parts that don't come loose, especially if it's plastic! Oh, and about your letter to MB, in my opinion (and as I often tell my letter-writing father), it is a waste of time and energy to send such a letter. I don't really think that MB or any other manufacturer would change their engineering to satisfy someone that sent a complaint letter...I'm not arguing, just stating my opinion. Thanks to all for your posts! |
(Post 3298114)
Originally Posted by vettdvr
(Post 3298797)
Unfortunately I agree with this. Too many companies today have missed that profits come from satisfied customers :bow:, and they think profits come from mass sales:X.
(Post 3298114)
I made a huge mistake, however, and I "neanderthaled" the plastic connection between the filter unit (on driver side) and fuel pump (on passenger side), so it broke! I just couldn't find the clip that would allow the barbed connection to release - VERY IMPORTANT! I admit that I am sometimes a neanderthal. ...................... Regards, paul... |
Today (11 Jan 2011) I stopped by the local dealer because of a noise I started hearing the day before. The noise was from BEHIND me as I was driving and sounded like a soft fluttering as would be from a slow-speed electric fan. Initially, I thought I'd left something in the back seat or trunk that some how came on and was running.
The sound finally became audible enough for a technician to hear it (I could hear it all along). They put it up on a rack and said it was coming from the fuel pump at the fuel tank. My service advisor (SA) said it was a low pressure pump that delivered fuel to the high pressure engine fuel pump. In checking the service records and querying me about my time owning the car, he could not find any record where the AIR & FUEL FILTERS were ever changed. The car had about 46500 miles on it when I purchased it in 2007. It was a lease return vehicle. These two filters were suppose to be changed at 20,000 mile intervals. Both items were changed and the fuel filter element "looked pretty dirty" as per the SA. He said that they had seen cases where the filter was not changed and the fuel pump in the rear labored more and more until it failed. He said the noise was gone and, hopefully, the fuel pump will be O.K. If the noise comes back, the pump will need to be replaced. We hoped for the best. I'm puzzled that the filters would have slipped thru the cracks and not be noticed all this time. Anyway, this is my story and I'm sharing it. I'd really like to hear from anyone who has had any similar experienced related to what I've described above. The final tab was just under $320 USD. Happy 2011..........Hez with a 2005 E320/CDI with 93k miles |
Just thought I might chime in here. Even with the PDF and the fact that this could be a DIY job, I elected to have my Indy perform the job. Today, this part goes for about $235. I got a killer hourly rate, but my indy did end up snapping a sensor bracket subsequently causing a CEL. He's since repaired this issue too. I find it apalling that a simple fuel filter is this difficult to replace. Filters are maintenance items and if MBUSA recommends they be serviced, then they should not be located in the tank. And if they are in the tank, maybe they're not meant to be maintained/serviced and we should be told that as well.
I also had my Indy perform a brake flush on the SBC brakes. Again, another technological fail on this car. I'm disappointed in the challenges this car has from a maintenance POV, but that is balanced by how wonderful it drives. I can't fault that. I just hope that after the work that's been done to this car since I took ownership in early 2009 (air filter, charcoal, oil changes, cam position sensor, aux battery, fuel filter, brake flush, etc), that basic oil changes are all that's needed until we replace it. |
Just thought I should post a follow up to my fuel filter replacement since the thread above.
Sadly, I now have a malfunctioning fuel guage because of what I can only assume is related to the fuel filter being changed out earlier this year. Since it's now June, obviously it's been more of a minor inconvenience but I do wish to resolve the issue. Basically, whenever I top off my tank, the fuel guage will not show as full. It misses the mark by two bars. I plan on reviewing the PDF's found in this thread and seeing if the following areas are either not plugged in properly, misaligned, or not working altogether - fuel float left side - fuel float right side - fuel level sensor - placement of fuel filter assembly Have any of you experienced a bad fuel guage reading since having your fuel filters changed out and if so, care to share any solutions you found? thanks |
